Author Topic: Roden SPAD VII 19 Sq. RFC 1/32nd scale:SPAD VII Lafayette:Nieuport 28 94th Aero  (Read 110615 times)
Offline Pup7309
Re: Roden SPAD VII 19 Squadron RFC 1/32nd scale
« Reply #15 on: January 28, 2021, 02:41:24 PM »
Great stuff. Like the canvas effect on your first effort and camo on the Salmson!
‘Not all who wander are lost‘
« Reply #16 on: January 28, 2021, 11:39:08 PM »
Looks like it has a lot of surface detail.  Nice!
« Reply #17 on: January 29, 2021, 01:42:50 AM »
Excellent progress on your build Rick , lovely job on the inners to boot !
I do like the second option better then the first one , then again with stripes it's hard to argue with that  :)
« Reply #18 on: January 29, 2021, 03:41:49 AM »
Wow, the fuselage is already closed - that can be called progress!
I'm sure it will be a nice add on to you collection of SPADs.
Offline Fvdm
« Reply #19 on: January 29, 2021, 04:43:57 PM »
I haven't been on the forum for a couple of days and there's another great subject with the fuselage already closed. I see a lot of louvres, are you gonna open them up? I have a Spad in the stash so I wonder if it's possible.
Nice work on the cockpit.
« Reply #20 on: January 29, 2021, 11:39:12 PM »
Thanks!
Yes, the surface detail is nice but I will lose a lot sanding  :-[
Thanks Alexis!
Thanks Frank, I hope it ends better than the First one  8)
Thanks for commenting! The louvres can be opened but I will use a wash. Trying to keep this one as simple as possible  ::)
I added the lacing to the left fuselage side using Archer Fine Transfers Decal:
PS: I still have a bit of filling and sanding to do  ::)
« Last Edit: April 12, 2021, 12:45:56 AM by RAGIII »
« Reply #21 on: January 30, 2021, 01:46:05 AM »
Great work and quick!
« Reply #22 on: January 30, 2021, 03:27:50 AM »
Thanks Fredrik!
« Reply #23 on: January 30, 2021, 03:46:47 AM »
Wow, Rick, you really snuck this one right in under the radar! But lovely and really beautifully detailed work! And what a great subject... I'm enjoying this a lot! Regards, Marc.
« Reply #24 on: January 30, 2021, 04:14:20 AM »
Thanks Marc! I am not really doing anything special on this one. Far less interior detailing than on the SPAD XIII's  ;D This one will be more about the scheme than the detail...or so I hope  8)
« Reply #25 on: January 30, 2021, 07:17:47 AM »
Really Rick! First you write that you did not intend to post a build log, then when you do you go roaring away like an express train! How are we supposed to keep up with you?
This has gone together so quickly I am struggling to keep up! I notice that once again you are adding lots of lovely detail which you then proceed to (rapidly) cover up!
Either of those schemes would be good - but it is your choice and I am sure that whatever you choose it will be another great model.
« Reply #26 on: January 31, 2021, 01:36:58 AM »
Thanks Stephen I always appreciate your comments! I have chosen scheme #2 and have oredered some serial number stencils from Von Buckles  8)
« Reply #27 on: January 31, 2021, 02:05:18 AM »
Wow, that fuselage really looks great. These Archer stitchings look much better than PE stitching, I am thinking of buying that stuff.
Andread
« Reply #28 on: January 31, 2021, 06:07:55 AM »
Andread
Thanks Andreas. The Archer Transfers are great. That being said they are NOT cheap! Also get them while you can as I saw something on FB that said they No Longer have access to the resin they used.
« Reply #29 on: January 31, 2021, 08:50:45 AM »
and a VERY SMALL update: I added the spent shell chute and the Copper State Models Vickers is ready to be permanently mounted when needed.
« Last Edit: January 31, 2021, 09:45:37 AM by RAGIII »
