Author Topic: Stearman PT-17 (1/32, Roden)  (Read 20419 times)
Offline Pup7309
Re: Stearman PT-17 (1/32, Roden)
« Reply #15 on: January 25, 2021, 08:39:18 PM »
Looking good ! Will follow with interest :)
‘Not all who wander are lost‘
« Reply #16 on: January 25, 2021, 08:41:58 PM »
I was mistaken about Vector, but Silverwings has the Lycoming R-680 listed, no other information, might be worth an email if you're interested.
Dave.
Ah, now I see why I could not find it. The problem is that PT-17s in 1940s, as my example, were powered by Continental R-670 engines, not Lycoming...
Thank you, Pup7309 for your comment and interest.
« Last Edit: January 30, 2021, 07:33:14 AM by PrzemoL »
« Reply #17 on: January 28, 2021, 06:04:43 AM »
Some colours applied. And the engine looks just fine to my taste. I will not do anything to its shape.
« Reply #18 on: January 28, 2021, 06:53:15 AM »
Looking fine, engine and inside structure.
« Reply #19 on: January 28, 2021, 09:13:25 AM »
Engine looks good under primer .  :)
« Reply #20 on: January 28, 2021, 11:48:52 PM »
Nice work.  The painted structure inside the fuselage sides looks good.
« Reply #21 on: January 29, 2021, 07:43:00 AM »
Thank you.
Some progress, the interior painted, assembled and enclosed. The headrests have nasty gaps which will be filled, sanded and airbrushed, soon.
« Reply #22 on: January 29, 2021, 09:52:13 AM »
The cockpit is taking shape wonderfully . Don't like the gap at the head rest , makes it weird to fill in .
« Reply #23 on: January 30, 2021, 04:16:41 AM »
Beautiful work, Przemo! I'm enjoying the slightly different techniques used here... ATB, Marc.
« Reply #24 on: February 05, 2021, 10:49:49 PM »
Thanks, Marc.
And, yes, Alexis, the headrests looked nasty but now they are filled, sanded and painted.
Lots of other cleaning all around, too. But it is slowly taking shape and heading for true colours.
« Reply #25 on: February 06, 2021, 03:23:09 AM »
Excellent outcome with filling in the head rest Prze  :)
« Reply #26 on: February 07, 2021, 09:44:53 PM »
Thanks, Alexis.
The lower wings attached with zero dihedral. The joint is very loose, they could literally flap, so the cardboard jig was vital. Now to fill the joint gaps, the CA glue will also add more strength. Also the undercarriage subassies are prepared.
« Reply #27 on: February 07, 2021, 11:06:32 PM »
Over fit of that wing looks decent from your photo . I do like the extra long mounting tap on the wheels and should give it that support it will need .
« Reply #28 on: February 09, 2021, 06:52:00 AM »
Again a very clean build and paint job!
« Reply #29 on: February 12, 2021, 09:06:41 PM »
Thanks!
The bulk is taking shape, seams filled and sanded, heading for rigging preparations and airbrushing.
