Author Topic: Stearman PT-17 (1/32, Roden)  (Read 20189 times)
Offline Early Bird Fan
Re: Stearman PT-17 (1/32, Roden)
« Reply #45 on: March 09, 2021, 05:51:44 PM »
the paintwork looks fantastic, once the blue is on it's really going to pop
Offline Berman
« Reply #46 on: March 10, 2021, 02:29:57 AM »
 Streamline rigging wires. I have read that photoetch RAF type wires can contract and expand, due to temperature changes, leading to problems. Flat elastic does not add any strength to the wing structure like nylon monofilament. Could flat nylon monofilament be created by passing  regular round monofilament through a cranked jewelry rolling mill at near zero clearance?  Too expensive to purchase one these but maybe a jeweler would let you use his for a few minutes.
« Last Edit: March 10, 2021, 04:32:26 AM by Berman »
« Reply #47 on: March 10, 2021, 04:07:17 AM »
Streamline rigging wires. I have read that photoetch RAF type wires can contract and expand, due to temperature changes, leading to problems. Flat elastic does not add any strength to the wing structure like nylon monofilament. Could flat nylon monofilament be created by passing  regular round monofilament through a cranked jewelry roller set at near zero clearance?  Too expensive to purchase one these but maybe a jeweler would let you use his for a few minutes.
I have seen on FB that some Modelers are letting one end of the steel PE wires "Float Free" in a tube used as an anchor allowing it to move when the wing flexes. I don't know what method Przemo will use but I am sure his skills will prevail  8)
« Reply #48 on: March 10, 2021, 08:46:13 AM »
I am afraid that I will disappoint you. I am planning the ordinary rigging of black 0.16 mm fishing line with the polyimide tubing to imitate the anchors.
« Reply #49 on: March 10, 2021, 10:58:57 PM »
Not disappointing at all. No need to complicate the build IMHO.
« Reply #50 on: March 11, 2021, 01:24:09 AM »
"The hard struggle with yellow paint is over."
Prze,
The next time you spray yellow, try undercoating with pink. It works!
Looking lovely.
vB
« Reply #51 on: March 12, 2021, 05:59:36 AM »
Prze,
Looking lovely.
vB
Pink you say. I would have never supposed it. Thank you, Bob, I will give it a try when I will tackle Tiger Moth...
And with blue it was a piece of cake, a pure joy of airbrush work...
« Reply #52 on: March 12, 2021, 07:48:29 AM »
The blue looks great. Looks awesome with the upper wing mounted and totally different with the red/white/red roundels!
« Reply #53 on: March 16, 2021, 09:49:17 PM »
Now that is a really nice shade of blau !
« Reply #54 on: March 17, 2021, 06:23:39 AM »
Great that you like the blue. It is the one recommended by Roden in the kit instructions.
More fun
« Reply #55 on: March 17, 2021, 12:03:14 PM »
Beautiful clean work. The Stearman always had a look I admired. Saw a few of them flying at airshows etc.
« Reply #56 on: March 21, 2021, 07:18:19 AM »
The final assembly and rigging underway. The end is near!
« Reply #57 on: March 21, 2021, 10:16:55 AM »
What can one say but Outstanding work! Especially on a kit that was "Unbuildable"
« Reply #58 on: March 21, 2021, 10:25:34 AM »
Very pretty !
Looking forward to the final pic's ! :)
« Reply #59 on: March 22, 2021, 08:26:34 AM »
Thank you, Alexis and Rick, for your continuous support. No doubt that you have a share in the completion of this "unbuildable" model. Done!
A couple of tentative shots, the proper gallery will follow soon.
