Author Topic: Hasegawa P-38J  (Read 30895 times)
Re: Hasegawa P-38J
« Reply #60 on: February 18, 2021, 02:49:19 AM »
Hi Kevin ,
No , a jig will not be need to assembly the booms . When I test fitted all the main parts it lines up ...but I will knock on wood just for good measure . :)
It has been about 25 years since I started mine but I seem to remember their being a misalignment issue with those booms so be careful! Your cockpit is looking great  8)
Re: Hasegawa P-38J
« Reply #61 on: February 18, 2021, 06:34:51 AM »
Thanks for check in Rick and for following along .
I guess in a few days I will find out how well my test fitting efforts where . Only other P38 I built was Monograms kit and Revell 32 scale and that is going back 30 years !
Thanks for sharing you experience with this kit .
Re: Hasegawa P-38J
« Reply #62 on: February 18, 2021, 10:22:21 AM »
Well Rick , you had me wondering on the fit of this now so I went and began gluing items together .
I started by adding the right boom followed by the left side , let this tack up for a half an hour . Tail was glued in next . Ever thing line up with min gaps , under side of the wing root will need filling in , but more on that later . I have a plan ..a cunning plan  ;)
A few more colours added to the pit and started the first round of weathering . A dry brushing of alum and a wash of future with black paint mixed in . Now comes the rest of the PE parts then final weathering .
Re: Hasegawa P-38J
« Reply #63 on: February 18, 2021, 10:22:44 AM »
Re: Hasegawa P-38J
« Reply #64 on: February 18, 2021, 10:23:05 AM »
Offline Radarman
Re: Hasegawa P-38J
« Reply #65 on: February 18, 2021, 10:53:51 AM »
Alexis,
It looks like you've got it all lined up and true.
                                              Great job,
                                                       Kevin
Re: Hasegawa P-38J
« Reply #66 on: February 18, 2021, 11:25:27 PM »
Thanks Kevin  :)
I'm tickled to pink that it lined up and didn't have to spend hours sanding and carving plastic to get parts to fit .
Re: Hasegawa P-38J
« Reply #67 on: February 19, 2021, 12:53:48 AM »
Thanks Kevin  :)
Yep, Good job on lining it all up. Perhaps the twist was only in the earliest issues of the kit or more probably you are just that good  8)
Re: Hasegawa P-38J
« Reply #68 on: February 19, 2021, 01:16:01 AM »
The booms look straight and squared. Well done.
Re: Hasegawa P-38J
« Reply #69 on: February 19, 2021, 02:55:07 AM »
I understand your concern about getting the booms square - everything looks awful when they are not. However that looks the part - so now looking forward to seeing this one completed. Another excellent build from your workshop Alexis.
Re: Hasegawa P-38J
« Reply #70 on: February 20, 2021, 07:51:19 AM »
Thanks guys !
I finished off the pit and have rest of the fuselage closed up awaiting for the seems to get address .
Re: Hasegawa P-38J
« Reply #71 on: February 20, 2021, 07:51:44 AM »
Re: Hasegawa P-38J
« Reply #72 on: February 20, 2021, 07:52:13 AM »
Re: Hasegawa P-38J
« Reply #73 on: February 20, 2021, 07:52:35 AM »
Re: Hasegawa P-38J
« Reply #74 on: February 20, 2021, 07:53:06 AM »
