Author Topic: Toms Model Works Pfalz D.VII/III  (Read 59276 times)
Re: Toms Model Works Pfalz D.VII/III
« Reply #90 on: December 10, 2020, 03:20:06 AM »
This one certainly is looking good.
There's that Beechcraft tail !
« Reply #91 on: December 10, 2020, 12:13:05 PM »
Thanks Kevin and Ken  :)
Kevin , yes I have chosen a scheme for this one . Will do Paul Baumer's kite for this one  ;)
Today I spent the time on starting the detailing on the engine to dress it up a bit and add some life to it . I cut 22 push rods and cut the push rod seats out of 5mm brass tubing . The push rods are 3mm and slide right in . Induction pipes are robbed from the parts bin and the spark plugs I still have to trim to size once the glue has fully set .
« Reply #92 on: December 13, 2020, 10:27:39 PM »
I am just catching up on this one Terri. WOW! I think that is one of your best interiors of Many great builds! The Model looks great closed up and your engine should look Spiffy with all of those Push Rods  ;D
« Reply #93 on: December 14, 2020, 08:49:54 AM »
Thanks Rick ! :)
It came down to ...I can't put this off anymore . Marking the holes in the wings for the strut locations . These aren't mark on the kit parts so rather then spend hours measuring it all out here is another way to mark them . For this I used the scale drawings in Jack Harris book . I lay down Tamiya tape over the plans . Center was marked matching the kit part . I used a black pen marking the strut locations . Pulled the tape off the plans and laid it down on the underside of the top wing lining up the center marks . Lower wings was done in the same manner but I used the wing root edge and the outer edge tip drawing that on the the and marking the strut locations . I used a awl pressing it down on the black dot's . The ink will transfer in to the dents made leaving marks to drill for the struts .
« Reply #94 on: December 14, 2020, 08:50:16 AM »
« Reply #95 on: December 14, 2020, 08:50:55 AM »
Offline Radarman
« Reply #96 on: December 15, 2020, 12:33:44 AM »
Happy Monday, Terri,
Things should move along well now that you've established the strut locations.
It's all looking great.
                                     Kevin
« Reply #97 on: December 15, 2020, 07:53:09 AM »
Hey Kevin , thanks for dropping by with continuing support  :)
« Reply #98 on: December 16, 2020, 07:57:11 AM »
Did a little bit more on this one and have the hinge detail added and pins . This was done in a simple manner . The wings are very thick and I'm not spending the time sanding them down , nor do I feel like making new ones . Tail planes are flared in as well and more work on the cowl . The top of the fuselage in not shaped right and will take a fair bit of putty to fix this so I made adjustments to the cowl . Still a bit of clean up to do on the underside but I can live with how this turned out . The fuselage is miss matched and is a challenge on getting things lined up and looking some what ..not have ass bad !
« Reply #99 on: December 16, 2020, 07:57:33 AM »
« Reply #100 on: December 16, 2020, 07:57:59 AM »
« Reply #101 on: December 16, 2020, 11:12:18 PM »
Wow, that cowling looks like real metal.
You're coming along well on this one.
« Reply #102 on: December 17, 2020, 04:48:22 AM »
Ken, I could have bet you made a cowling for Terri on your lathe!
« Reply #103 on: December 17, 2020, 11:15:07 AM »
Hi guys ,
Ken , that's because it is metal ;) . I did some polishing to get out the fine scratches from sanding . This will be painted white in the end , but I do like how nice and shine it is .
Frank , do you think he would do one for the nieuport  ;)
« Reply #104 on: December 22, 2020, 12:26:20 AM »
Outstanding work on the strut locations and tail construction Terri! That cowling looks amazing...too bad it needs to be painted!
