Author Topic: Toms Model Works Pfalz D.VII/III  (Read 59379 times)
Re: Toms Model Works Pfalz D.VII/III
« Reply #240 on: February 20, 2021, 07:45:50 PM »
Nice job Alexis  ;)
« Reply #241 on: February 20, 2021, 10:19:16 PM »
Thanks Ed and Guy  :)
I did spend about an hour on this yesterday and was able to get the warp out of the lower wing tips . Rigging can finally start now , should have the rigging done in a few days .
« Reply #242 on: February 21, 2021, 12:51:48 AM »
Great Progress !  Keep it up !!!
I have to agree with My Amigo!
« Reply #243 on: February 21, 2021, 11:08:46 AM »
I will try Rick ,
It did get pulled out of the trash , I thank you for that  ;)
« Reply #244 on: February 21, 2021, 12:17:30 PM »
I will try Rick ,
That's what Friends are for Alexis! Take your time and get yourself together! You will know when you are ready!
« Reply #245 on: February 22, 2021, 01:23:15 PM »
Right now all I want to do is give you a big HUG !
Thank -you so much my friend  :-*
« Reply #246 on: February 22, 2021, 06:24:47 PM »
Glad to have you back Alexis!
« Reply #247 on: February 23, 2021, 01:03:10 AM »
Thanks Guy , I'm taking a break from building for now . Sooner or later this might get finished .
« Reply #248 on: February 24, 2021, 06:56:02 AM »
Wasn't able to look into this board for some days ....
Ooops :o
What happened here?
Ok, understandable! Take a deep breath of fresh air .... and come back one day with recharged batteries :-*
« Reply #249 on: February 24, 2021, 10:40:52 AM »
Hi Frank ,
Yes , I had a co-vid melt down and real need a break form stuff that is stressing me out . Still active , just not building for a bit .
Rick , Dave W and Guy have been a termedous aid in calming me down so I was able to think clear and regain my composure  :)
« Reply #250 on: March 06, 2021, 06:23:00 PM »
That happens, Alexis. No fault of yours. As you say, you can always come back to it again. Regards.
« Reply #251 on: March 07, 2021, 06:12:48 AM »
« Reply #252 on: March 25, 2021, 06:52:53 AM »
I did restart this last week but I sure didn't get far and ended taken a few more steps back . Cab struts are rigged after trying 3 times to get it and in the process drop it on the bench knocking lose the cab struts and two inter struts on the left side . Then again I also forgot to glue the two inter struts in place  ::) ::) ::) so.....I have re-gluing to do before I continue .
Offline Radarman
« Reply #253 on: March 26, 2021, 11:07:56 PM »
Alexis,
This kit must be full of traps and potential snags for the builder. I'm sure you will navigate through them.
        Kevin
« Reply #254 on: March 27, 2021, 12:31:23 AM »
Hi Kevin ,
Yes there are a lot of snags for the builder and one area I should have spent more time on was the fuselage shaping on the right side and I did jump the gun and should have done per-rigging on the top wing before mounting it which I sure cause some of my frustration . I have built worse resin kits then this ...but it ...it fights back hard . Not for the beginner that's for sure . I will get her rigged slowly and when that feat has been reached the rest should go pretty quick .
