Author Topic: 1:32nd scale - Bristol M1.c 'Bullet'  (Read 10779 times)
« on: October 05, 2020, 05:05:45 AM »
After the trials and tribulations of several resin model builds recently, I thought I'd do a 'mojo' build.
I've chosen the 'Special Hobby' 1:32nd Bristol M1.c 'Bullet'.
This particular model build will depict the Bristol M.1c ‘Bullet’, Serial No. C4907 of No.150 Squadron RAF, operating in Macedonia during 1918.
This aircraft was flown by Lt. K.B. Moseley, who was credited with the shooting down of an Albatros D.V on the 9th of July, 1918 over the Rupel Pass.
This same aircraft was also flown by Lt. J.P. Cavers, who was credited with the shooting down of a LVG on the 1st of September and another LVG on the 2nd of September.
The underside of the wings and fuselage were said to be a light blue colour, apparently to reduce the absorbed heat reflected from the ground.
It's thought the propeller spinner was of the same colour.
The colour of the upper surfaces has been depicted as either a red/brown (PC 12) or an olive green (early PC10).
The kit instructions and the colour profile by artist Ronnie Barr have the PC12 colour, whereas the ‘Windsock’ Data file colour is PC10.
As always the definition of colours from early monochrome photographs has always been problematic and the shade differences between PC10 and PC12 are no exception.
The ’Windsock’ Data file states that it may have been that these aircraft were painted with PC12 when routed through the aircraft depot at Salonika, Greece.
However, it was more likely the colour of aircraft operated in Macedonia were PC10, with the possible exception of No.72 Squadron.
I've decided to use the PC10 colour, based on the ‘Windsock’ data.
Offline Radarman
Re: 1:32nd scale - Bristol M1.c 'Bullet'
« Reply #1 on: October 05, 2020, 07:29:10 AM »
Mike,
This will be a great one to follow. I look forward to the PDF you produce in the end.
        Kevin
« Reply #2 on: October 05, 2020, 09:11:58 AM »
Looking forward to the build Mike .
« Reply #3 on: October 05, 2020, 09:39:15 AM »
As always I will follow closely!
« Reply #4 on: October 05, 2020, 03:06:25 PM »
Me too!
Offline fredjocko
« Reply #5 on: October 05, 2020, 09:54:44 PM »
I am looking forward to your build.
« Reply #6 on: October 05, 2020, 10:13:40 PM »
The engine for the Bristol is done.
It's the basic kit engine with just the ignition leads added.
The leads were made from twisted 0.125 mm copper wire and annealed to soften and discolour them.
The engine was painted with 'Alclad' lacquers - Black Base (ALC-305-60), Steel (ALC-112) and Exhaust Manifold (ALC-123).
The kit engine was used as it is a good enough quality not to require an aftermarket version.
Besides, once fitted, very little of the engine will be visible inside the engine cowl and behind the propeller and huge spinner.
Now it's onto the cockpit,
« Reply #7 on: October 05, 2020, 10:30:00 PM »
Nicely done Mike!
« Reply #8 on: October 06, 2020, 03:05:54 AM »
The engine looks great and the decision to follow the windsock indications is what I would have decided.
I look forward to see more on this build!
« Reply #9 on: October 07, 2020, 07:17:26 AM »
I'm working my way through the cockpit assembly.
Most is assembled ready for painting.
There are other parts to add after they've been painted.
I've drill 0.3 mm diameter holes and added 'GasPatch' 1:48th 'one end' turnbuckles to the rudder bar.
Added a 0.3 mm rod to the control column to add strength to its attachment to the floor (hole drilled to receive the rod).
I've also drilled 0.3 mm diameter holes across the control column for the elevator control wires.
The instrument panel of the cockpit right side frame is orientated incorrectly in the instructions.
The photograph shows how it was mounted, so I've gone with that,
« Reply #10 on: October 07, 2020, 08:48:10 PM »
Excellent progress Mike. The quality and speed of your builds Amazes Me!
« Reply #11 on: October 07, 2020, 08:57:29 PM »
Nice job on the engine and the pit is off to an excellent start  :)
« Reply #12 on: October 08, 2020, 12:36:40 AM »
Good start, Mike.  Interesting mounting of the turnbuckles in the rudder bar.
« Reply #13 on: October 11, 2020, 03:38:14 AM »
Most of the cockpit has been assembled now.
The control lines and bracing lines are 0.08 mm diameter mono-filament, with 0.4 mm diameter Nickel-Silver tubes and 'Gaspatch 1:48th scale turnbuckles.
I've still fit the engine controls and rods and the pilot's seat with harness.
Then it's a bit of weathering and finally sealing, to add the semi-sheen finish to the wood work and leather seat cushion,
« Reply #14 on: October 11, 2020, 07:46:52 AM »
Beautifully done Mike!
