Author Topic: 1:32nd scale - Bristol M1.c 'Bullet'  (Read 10891 times)
Re: 1:32nd scale - Bristol M1.c 'Bullet'
« Reply #45 on: October 29, 2020, 05:21:20 AM »
Looks even More beautiful with Markings. The colors and addition of fabric finish decals are Truly Stunning!
« Reply #46 on: October 29, 2020, 07:47:42 AM »
The back end has now been rigged with rudder and elevator control lines and fin cross bracing.
Also the ailerons control lines are done, as is the undercarriage cross bracing.
Now it's onto fitting and rigging the wings,
« Reply #47 on: October 29, 2020, 07:56:14 AM »
Simply awesome Mike!
« Reply #48 on: October 29, 2020, 08:35:45 AM »
Fantastic colours that are heightened even more by the linen decals. I will have to get some of those for future builds.
« Reply #49 on: October 30, 2020, 11:52:49 PM »
The Bristol M1.c is finished now, although I still have the figures and display base to do.
The shot below (minus propeller and spinner) is of the wing rigging, which turned out to be more difficult than I had hoped.
Having built monoplanes before, I didn't anticipate how tricky it would be to fit the wings.
The actual aircraft had a wing dihedral angle of between 2 and 3.5 degrees.
However the two locating lugs at the root of each wing are woefully inadequate.
The wings are moulded a single, solid pieces, so are quite heavy.
Test fitting both wings into their locating holes in the fuselage proved useless as the both wings sagged down badly.
I couldn't drill into the wing roots and through the fuselage to add metal rod 'spars for additional support  (as I've done before on mono-planes).
They would have crossed through and been visible in the cockpit.
Therefore I decided to fit the flying and landing wires as the wings were fitted.
In that way the wires actually supported the wings onto the over cockpit support frame, which I'd made from brass tubing.
« Reply #50 on: October 31, 2020, 01:10:50 AM »
Another superb build from start to finish Mike. I am looking forward to seeing the figures and base!
« Reply #51 on: October 31, 2020, 01:24:56 AM »
Beautiful!
The linen decals are very effective.
« Reply #52 on: October 31, 2020, 07:04:38 AM »
I've finished the mechanic ('Copper State Models'), who will be pulling the propeller to prime the engine.
I wanted him to look grubby and oil stained.
Painted with 'Tamiya' and 'AK Interactive' acrylics.
Weathered with 'Flory Models' clay wash and 'Tamiya' Weathering Master Sets A, D and C.
Now it's onto the pilot,
« Reply #53 on: October 31, 2020, 10:03:37 AM »
Looking forward on seeing her on the base Mike  :)
« Reply #54 on: October 31, 2020, 10:12:52 PM »
I've finished the pilot ('Kellerkind Models').
I think he's probably slightly over dressed for operating in Mesopotamia, but hey-ho.
Painted with 'Tamiya' and 'AK Interactive' acrylics and 'Mr. Colour'.
That's it now so thanks for your support and comments.
The next post will be the final reveal of the completed model,
