Author Topic: Don't get PUSHY with me !  (Read 65353 times)
Re: Don't get PUSHY with me !
« Reply #165 on: February 08, 2022, 11:43:48 AM »
Bit more was achieved today with adding hinge details to the tail planes and bolt heads cot form .5mm and .8mm hex rod . I will cut the tail skid free and add a brass pin in this location as well . I sure it will hold the weight but the plastic is soft which might cause sag issues in the future . Once that is wrap up this part will get assembled as a unit .
« Reply #166 on: February 09, 2022, 02:14:18 AM »
Awesome updates Alexis. If you keep this up I might have to get the Roden DH2  ???
Offline NinetythirdLiberator
« Reply #167 on: February 09, 2022, 05:01:46 AM »
Alexis secretly works for Roden.
Great at sales!!!!  ;D ;D ;D
Dan
« Reply #168 on: February 09, 2022, 06:23:13 AM »
Dan
Hey! Deep cover detective work is my bag, Dan!  ;D ;D
« Reply #169 on: February 09, 2022, 08:15:32 AM »
Thanks Rick , I believe you should pick up Rodens kit . Really enjoying the build so far and so far everything fits .
You know Dan , you were to be keeping that under wraps , just saying !  ;)
You spying on me Zac ? ! I have a pretty good air farce in the waiting you know  ;D
« Reply #170 on: February 10, 2022, 02:24:05 AM »
;D ;D
Offline Grant
« Reply #171 on: February 10, 2022, 06:15:57 AM »
Alexis,
After I finish up my MENG DR1 Fokker its onto this kit, looking really great Alexis and giving me some good ideas!
« Reply #172 on: February 12, 2022, 02:57:59 AM »
Shaping up very well indeed Alexis. Another pusher looks as though it is going to be completed soon - and another little gem from your bench.
« Reply #173 on: February 13, 2022, 12:16:38 AM »
Good progress here, Alexis.
Regarding the tail skid - the Roden plastic is soft but it has not sagged on mine.   Where you will notice a bit of weakness is in the tail booms.  I used Oshci standard elastic thread for cross bracing but then used nylon line for the wires that support the structure from the wings.  The model still has a bit of 'bounce' in the tail but is definately strong enough to support the weight of the model.
« Reply #174 on: February 13, 2022, 10:19:06 AM »
Having to work under the cloak of night in a tiny shed , work continues with the tail assembly with rest of the rigging holes being drilled . The tiny mounting Locations for the rigging on the boom struts I removed and a small hole was drilled passing all the way threw . Haven't give much thought on how I will do the rigging , but at least the holes are there now rather then having to do this later . the rear strut is pin with brass rod and I ended up breaking part of the boom . The rudder is is glued the tail plane and once this is has set to dry over night test fitting on the booms will be next .
Thanks guys for tagging along with your continued support !
« Reply #175 on: February 13, 2022, 10:19:36 AM »
« Reply #176 on: February 14, 2022, 12:18:58 AM »
Shaping up nicely, Alexis.
« Reply #177 on: February 14, 2022, 01:18:22 AM »
Looking fine Alexis! Your assembly sequence is interesting. I will have to keep that in mind if I tackle a Roden DH2 in the future!
« Reply #178 on: February 14, 2022, 03:39:35 AM »
Thanks Ken , my rear is shaping up nicely ! Thanks for noticing  :) :) :)
Rick , in all honesty I haven't followed the instructions what so ever and all this I just winging it working with the space I have now ...I miss my huge work area . So I'm really not sure if this is the best way to go , time will time I guess !
« Reply #179 on: February 14, 2022, 04:52:26 AM »
Always worth trying new ideas even if it is to prove that they do not work! I suspect that yours will work though Alexis - and given the conditions in which you are trying to build this I think that you are very successful.
