Author Topic: Don't get PUSHY with me !  (Read 65332 times)
Re: Don't get PUSHY with me !
« Reply #135 on: January 17, 2022, 09:58:49 AM »
Thanks Stephen ,
Lot's of time , still a fair amount of stuff still left to do . Speaking of which I decided to spend some time on this one by continuing working on some of the smaller details .
The alex bar I replaced with rod , saves time on cleaning up the kit one I punched new disc , drilled them out and slide them in place . Much better now methinks .  Not sure what was going on with the prop and I should have taken a picture of it first , but I didn't . The back side need some filling in , I punched a few disc glued them in place filling the gaps with tamiya white putty . Once this is dried sanding will take a bit . Also punched disc for the prop bosses front and back and that as far as I got so far .
« Reply #136 on: January 17, 2022, 09:59:13 AM »
« Reply #137 on: January 17, 2022, 07:36:58 PM »
Good to see you back on this one again, Alexis.
This Roden kit is really pretty decent.
« Reply #138 on: January 18, 2022, 12:47:53 AM »
I first thought the 'alex' bar had something to do with your name, but then I figured out you meant axle.   ;D
Nice fixes.
« Reply #139 on: January 18, 2022, 02:37:54 AM »
Godd progress Alexis. Certainly moving in the right direction.
« Reply #140 on: January 18, 2022, 04:10:16 AM »
Great progress, Alexis
I was a bit confused too!  ;D
« Reply #141 on: January 18, 2022, 04:38:30 AM »
Glad to see you progressing with this Alexis.
WD
« Reply #142 on: February 01, 2022, 09:21:58 AM »
Thank you so much guys , really means a lot to me  :)
Been rather busy of late and haven't had much of a chance to sit in front of the work bench . I do volunteer counselling on a support site so some of my spare time goes to helping others .
I did manage to get a bit of progress made , moving forward is always a positive . The start of replacing the prop boss is under way . I punched disc out of .15mm sheet for the front and back plates . Brass bolts are used the front and on the back side I will use plastic instead . The center still needs a few bits , but it is getting there . The landing gear is glued up as well waiting for further detailing .
I filled in the back side of the prop , but my shaping skills are to be desired so it will have to do . Not a thumbs up or thumbs down so I'm happy .
« Reply #143 on: February 01, 2022, 09:22:42 AM »
 :) Me back side !  ;)
« Reply #144 on: February 01, 2022, 09:23:37 AM »
And check out those legs , nice hey !  :)
Offline Radarman
« Reply #145 on: February 02, 2022, 01:03:13 AM »
Alexis,
This is sure to be a great build once all these sub-assemblies join up.
I always enjoy your updates.
                                               Kevin
« Reply #146 on: February 02, 2022, 01:09:28 AM »
The prop and gear look excellent Alexis!
Offline Stuart Malone
« Reply #147 on: February 02, 2022, 01:35:57 AM »
Alexis,
You have far more patience than me.  Can I borrow some?  Very nice cleanup and detail work.
Stuart
« Reply #148 on: February 02, 2022, 05:07:53 AM »
What kind of excuse is that? We want models!  ;D Just kidding, as someone who has spent much of the last year tackling his own issues I can't put into words how valuable kind-hearted folk such as yourself really are.
« Reply #149 on: February 02, 2022, 05:45:30 AM »
This is real progress Alexis: the spinner parts look good yto me and most observers will never get close enough to scrutinise it anyway.
Really looking forward to seeing another real aeroplane being completed.
