Author Topic: Meng and Roden Fokker DR1: Jasta 4, Jasta 6, and Jasta 11  (Read 149742 times)
« Reply #150 on: October 26, 2020, 02:47:13 AM »
Rick, your streaking looks good! Not that easy to get it right, and I know that because I'm doing the same now ::)
Which Tamiya paint you use for CDL? For the Fokker I like to have a less yellow, more greenish and your shade looks like that (ok, camera, light and monitor may manipulate the color ...).
« Reply #151 on: October 26, 2020, 03:02:01 AM »
Nice work there! Streaking is looking great
Thanks Dave, Greatly Appreciate you looking in!
Steaking is very nice Rick!
Thanks Kent!
Thanks for commenting Frank! As for the Tamiya CDL I am pretty sure it started as "Buff". I might have mixed in some grey. I used a mix I had sitting on the shelf so I am not 100% sure  ::)
« Reply #152 on: October 26, 2020, 06:04:55 AM »
The lower wing and fuselage are finished...Streaking that is  8)
« Reply #153 on: October 26, 2020, 06:28:37 AM »
Looking at the two Rick there are clearly tonal differences (but bear in mind Frank's comments), but I think that both are very good. I suspect that in reality different aircraft did look slightly different because paints would have varied and the people painting the streaking would have had different patterns too. So in brief: both get my vote! (And if I ever build a Fokker in the future I know who to send it to for painting!!)
« Reply #154 on: October 26, 2020, 07:20:10 AM »
Rick, you managed to keep the streaks in areas, where a huge amount of paint is removed. I tried it, but get quickly an uniform area.
« Reply #155 on: October 26, 2020, 07:40:54 AM »
. Frank, It is a matter of remembering that oils can be worked and then reworked. I remove large areas with a dampened wide flat brush then go back with a narrow brush adding what I want. If I don't like the results I remove and re-do.
Offline William Adair
« Reply #156 on: October 26, 2020, 01:37:11 PM »
They look fantastic.  The streaking is very beautiful.
« Reply #157 on: October 27, 2020, 02:34:14 AM »
Nice job on the streaking, Rick.
« Reply #158 on: October 27, 2020, 06:57:53 AM »
Moving along nicely Amigo !!
« Reply #159 on: October 27, 2020, 08:16:24 AM »
Thanks Amigo!
Thanks for the comments Stephen. I took a break today from the Fokkers to work on the Pfalz. The next steps should make these look better.
Thanks for dropping in and commenting!
Thanks Ken!
« Last Edit: October 27, 2020, 09:00:19 AM by RAGIII »
« Reply #160 on: October 27, 2020, 08:50:22 AM »
Now that is nicely done Rick  :)
« Reply #161 on: October 27, 2020, 09:00:42 AM »
Thanks T!
PS: I did apply one Roden cross decal. Got a small chip but will correct that when I convert the cross to the later open ended type.
PPS: The RODEN decal is working well although it was Brittle!. It is reacting to setting solution and a hair dryer. Other than the chipped portion I am pleased.
« Last Edit: October 28, 2020, 02:02:29 AM by RAGIII »
Offline Radarman
« Reply #162 on: October 27, 2020, 12:42:16 PM »
RAGIII,
The streaking looks great. I'm wondering whether you found using acrylics easier, harder or the same just different, than the oil paints you have used in the past?
        Thanks, Kevin
« Reply #163 on: October 27, 2020, 08:05:46 PM »
Beautiful colours! That streaking is really impressive.
« Reply #164 on: October 28, 2020, 12:27:17 AM »
RAGIII,
        Thanks, Kevin
Thanks Kevin. The Acrylics are certainly different than what I am used to! I found I needed to work more quickly and they were just a tad harder to get the look I was after. I worked "wet" and used water and a Filter/wash to thin and remove what I needed to. In the end I am more comfortable with the time that the Oils allow.
Thanks Fredrik!
