Author Topic: Meng Fokker Dr.I  (Read 28784 times)
Re: Meng Fokker Dr.I
« Reply #60 on: September 11, 2020, 04:16:26 PM »
Ps
As usual I managed to drop the horizontal stabiliser and knock off the moulded control horns. I struggle with finding a method to replace/add these that’s sturdy enough (as they’ll be under a degree of tension). Any thoughts here most welcome...
Offline Edo
« Reply #61 on: September 11, 2020, 04:47:31 PM »
well, to tell the truth I am not a big fan at all of Fokkers in general and DrI in particular, but your build makes me want to star one soon....
very inspiring indeed and wonderfully executed!
ciao
edo
« Reply #62 on: September 11, 2020, 05:27:26 PM »
That's unfortunate! It seems to me that the best way would be to make a hole straight through the wing in order to get a solid enough joint. I was going to say that you could open it up from the front edge of the elevator, but I see that the hole thing is molded as one piece, so I guess drilling through?!
Cheers Fredrik
« Reply #63 on: September 11, 2020, 06:06:48 PM »
Thanks Edo  :D
Fredrik, thanks, yes, I was coming to that conclusion myself. It’s going to have to be (brass) rod shaped though unless I can concoct something out of plastic card or similar that actually looks like a control horn... I’ll give that some thought.
« Reply #64 on: September 12, 2020, 01:23:05 AM »
Thanks Edo  :D
One of those control horns was the only thing that came disassembled in My kit. Luckily I have Eduard, Part, and Aviattic PE sets that include control horns. I will most likely go ahead and separate the elevator and cut slots to install the PE versions. I am sure you will sort your broken Horn out!
« Reply #65 on: September 12, 2020, 02:04:28 AM »
Just now scoping this out Guy:  The interior work is stellar if not absolutely outstanding.  If you hadn't said that the seat belts were WWII Luftwaffe, I would have never known.  They look quite good against the leather seat that also looks like real leather.  The streaking is most realistic and with an airbrush, I have only seen that done on one other model and that was a long time ago, yours looks great.  This is gonna be a barn burner.
« Last Edit: September 12, 2020, 02:15:12 AM by mgunns »
« Reply #66 on: September 12, 2020, 03:01:14 AM »
Great progress, Guy.  Nice painting.
Thanks for the closer look at the Meng Dr.1
Offline Europapete
« Reply #67 on: September 12, 2020, 10:36:56 PM »
Awesome job Guy, as everyone else has said, best painted streaking I have seen, well done. Regards, Pete in RI
« Reply #68 on: September 13, 2020, 02:08:08 AM »
Thank you,
I had a bit of a brain wave (unusual for me!), there’s a second tailplane in the kit (for the prototype) - different profile, but I’ve carved that to match the Dr.1 version and looks fine I think. Just gives me the control horns back.
I’ve finished the engine, and if I’m being honest, not a lot of work has gone into it, only a few parts (but nicely moulded) and just sprayed. I haven’t added any detail.
« Reply #69 on: September 13, 2020, 02:14:29 AM »
Man, that engine looks great!
« Reply #70 on: September 13, 2020, 07:11:33 AM »
Gorgeous engine!
« Reply #71 on: September 13, 2020, 04:12:41 PM »
Thanks Rick & Gary,
She’s progressed to being a biplane. Good fit so far - the wings click together like Lego - a welcome change from the Avro Manchester build! The further I get into the build, the more I like this kit. They are going to sell them by the bucket...
Thank goodness they sneaked this out in time!
Offline Early Bird Fan
« Reply #72 on: September 13, 2020, 04:32:00 PM »
i know the rest of it looks great but i can't keep my eye off those wings, stunning work  ;D
« Reply #73 on: September 13, 2020, 08:58:18 PM »
Thanks Early Bird,
Yes I am pleased with it. Better than I hoped at least.
Guns finished. Standard Wingnuts fare. I’m deliberately keeping everything simple and not weathering to any great extent. I’ll be happy with a clean cut finish on this one.
I have got the insignia masks and they’re top notch! Thanks Fredrik. I’ll post the results soon.
Ps just seen the end a little bent on one..  ???
« Reply #74 on: September 13, 2020, 10:30:30 PM »
Making some really excellent progress Guy , engine looks great out of the box so do the guns .
