Author Topic: Checker Time , Sopwith Camel  (Read 31226 times)
Re: Checker Time , Sopwith Camel
« Reply #30 on: August 13, 2020, 11:25:04 AM »
Now I hadn't thought of a two tone base for wood. I can see where that might have some applications. Thanks for the tip.
I have to ask. What is meant by "Filters" ? That was not a term bandied about back in the day and it is totally new to me. A tinted clear sort of thing?
sp
Hi sp , sorry for not getting back too you sooner . Read your post this morning but was in no mood this morning for typing . All is good now though and feeling much happier !
Yes , filters work wonders and help bring the whole effect together . For my base coat on my Lloyd build it has a two tone on the wings and fuselage . Same as the HB D.1 .
It is basically clear coating with a tint . You can make this tint as light or dark with any colour you want . ( also works most excellent for doing washes )  ;) When I do a filter a light brown is use for darker tones and a tanish for lighter tones . Before I do my finally clear coating panel lines and edges , around hatches I spray with thinned tamiya smoke slowly building this up , it doesn't take much to over do it . Filters you can build up different effects with in the tones going over a area with a few more passes then others .
Offline smperry
« Reply #31 on: August 13, 2020, 04:12:50 PM »
Thanks Terri. My go to clear is Future, so any filters I make up will be versions of tinted Future. Watercolors or watercolor pencil scrapings for lighter tint and acrylic paint for a more robust tint. Right now the only tinted Future I have is yellow acrylic that I use on props. I will make up light browns and redish browns as I do more wood. I had never heard the idea called filters. I will have to get some of that Flory wash. watched hos video and was most impressed. Works right in with clear coating and filters.
sp
« Reply #32 on: August 13, 2020, 10:57:05 PM »
Looking good Terri...
Offline Ian from Doncaster
« Reply #33 on: August 14, 2020, 05:38:33 AM »
Just to add to the tinted future idea, it’s something I use often but make a little up each time.
For a quick wood effect, I’ll spray a light tan base coat, then instead of using oils I “shade” with a variety of coloured pencils lightly dragged over the surface.  Then I’ll add a drop of brown acrylic paint into a half teaspoon full of future/klear and brush on, in several coats.  I do the same but with a drop of white or yellow paint to apply to clear plastic parts for fuel gauges, light fittings etc.
Sorry Terri, don’t want to distract from your build.. !  Just echoing your filtering   :)
Looking forward to more progress pics..
« Reply #34 on: August 14, 2020, 10:16:56 AM »
Your welcome sp  :)
Thanks Guy  8)
Ian , no need to be sorry for info which helps out others . Thanks for sharing  8) 8) 8) More progress will becoming soon , weekend is almost here !!!! ;D
« Reply #35 on: August 16, 2020, 10:21:07 AM »
Rest of the push rods are done and I'm ready to start the spraying for the black base for the alum .
« Reply #36 on: August 17, 2020, 10:37:55 AM »
Black basing is as far as I got on this one today . Weather was beautiful so I went for a walk and did my a bit stuff around the house .
« Reply #37 on: August 18, 2020, 02:51:19 AM »
Great start on painting the engine. I am looking forward to the next step Terri!
« Reply #38 on: August 18, 2020, 05:22:57 AM »
Certainly agree with Rick about the engine - looking very good. A walk in the good weather is an excellent idea - there will be plenty of time for modelling in the winter when the days are short and the weather awful!
« Reply #39 on: August 18, 2020, 09:37:52 AM »
Thanks guys  :) We have a fair bit of moisture in the air making it humid so I will give this a few days to cure a bit more before I start spraying the Vallejo Metal coat .
Offline AndRoby67
« Reply #40 on: August 21, 2020, 04:37:50 AM »
Hi Terri!
Good first steps in this build. I'm sure that you have, but this is photo of original one, here in Italy.
Good idea for diorama too.
My two cents!
Roberto
« Reply #41 on: August 21, 2020, 12:45:27 PM »
Thanks Roberto ,  yes I have the photo as well but thank you for posting . Eduard did get the " R " wrong for the decal but I'm going to leave it as is .
Engine was sprayed with Vallejo Metal Coat and a wash of black to highly the details and blacking the cylinders . Inductions pipes got the copper treatment and that is todays work on this one .
« Reply #42 on: August 21, 2020, 12:46:00 PM »
« Reply #43 on: August 21, 2020, 02:05:54 PM »
Good work on that engine, Terri!
« Reply #44 on: August 21, 2020, 09:35:51 PM »
Thanks Gaz  :)
