Author Topic: 1:32nd scale Siemens-Schuckert D.III (Early)  (Read 26297 times)
Re: 1:32nd scale Siemens-Schuckert D.III
« Reply #15 on: May 26, 2020, 12:34:09 AM »
Looks great Mike!  It's amazing how much the new pushrods improve the engine.  Very nice.
Best regards,
I agree completely with Bob!
« Reply #16 on: May 26, 2020, 01:25:33 AM »
    I did the same with my engine Mike, kept the Aviattic engine for display on a Scratch Built wood packing frame for the same reason and built up the Kit Engine which turned out just fine.Great start, I'm going to enjoy this!
« Reply #17 on: May 27, 2020, 01:03:20 AM »
I've amended the first post in this thread.
The aircraft I had intended to build was the later D.III version, but that model has been built by quite a few modellers.
So I decided to change to an 'early' D.III, which is a less common build and take up the challenge of incorporating the 'Loon Models' resin conversion.
This will entail replacing the engine cowl and support frame, tail plane/elevator assembly, propeller spinner, wing tips and ailerons.
Lets see how 'easy' this will be,
« Reply #18 on: May 27, 2020, 06:12:18 AM »
Sounds like a lot of mods with your trademark surgical precision are on the way Mike. I'm looking forward to this very much!
« Reply #19 on: May 27, 2020, 09:47:50 AM »
Ooooh and early bird !
Don't see many of them done up . I hope the Loon's model cowl fit's right for you . I have the late version set and the cowl isn't wide enough .
« Reply #20 on: May 27, 2020, 07:03:07 PM »
Great looking engine!
« Reply #21 on: May 27, 2020, 07:18:19 PM »
Yeah I've read the resin set for the later version has fit problems - Hopefully the earlier set will be less problematic.
Ironically the work I did on the engine will be more or less totally covered by the cowl and spinner - hey-ho,
« Reply #22 on: May 28, 2020, 09:59:16 AM »
Some of the earlier version didn't have the spinner  ;)
« Reply #23 on: May 31, 2020, 07:14:38 AM »
The engine is finished now.
The only changes I made (not that you'll see much once installed):
Valve push rods made from 0.4 mm diameter Nickel-Silver tube with 0.5 mm bases.
Ignition leads from 0.148 mm diameter black mono-filament.
Ignition lead plate at engine rear from 0.5 mm thick plastic card.
« Reply #24 on: May 31, 2020, 07:35:08 AM »
Looks good, Mike!
« Reply #25 on: May 31, 2020, 07:42:43 AM »
Outstanding Engine Mike!
« Reply #26 on: May 31, 2020, 11:48:19 PM »
Your engine fits the bill perfectly  :)
« Reply #27 on: June 01, 2020, 01:48:17 AM »
Onto the resin conversion set from 'Loon Models' (LO32006) for the early D.III aircraft.
The resin engine cowl is well formed but is so thin in places I can virtually see through it.
Also when offered up to the kit engine bulkhead, the resin cowl outer diameter is undersized, which leaves a step between it and the bulkhead.
As the resin cowl is way to fragile to contemplate modifying it, I chose instead to modify the bulkhead and fuselage halves.
The outer edge of the bulkhead was sanded to match the cowl.
The forward inside ends of the fuselage were scrapped to form a shoulder for the bulkhead to locate.
The end result is the fuselage. bulkhead and resin cowl now align.
The next step is to create the cooling slots and apertures in the bottom of the cowl (good thing the set has two cowls!!)
The early production SSW D.III aircraft were fitted with a full, circular cowl around the engine. In addition the propeller was fitted with a large domed spinner. These combined with poor engine lubrication, caused by the use of synthetic ‘Voltol’ oil, caused many engine failures. In an attempt to increase cooling airflow across the engine, some engine cowls had two oval apertures and three slots cut through the bottom/sides of the cowl. Although I could not find photographic evidence of this for the Jasta 15 aircraft of ’Ziegesar’, there is a photograph of the aircraft of Lt.d.R. Alfred Greven of Jasta 12, which clearly shows one of the cooling apertures.
Should be fun,
« Last Edit: June 01, 2020, 06:20:52 PM by Mike 'Sandbagger' Norris »
« Reply #28 on: June 01, 2020, 10:05:34 AM »
Yup same issues with my cowl , I do like your method for setting firewall/engine mount to get all to work . Looking forward on the next update  :)
« Reply #29 on: June 01, 2020, 08:38:35 PM »
Spectacular engine Mike, looking forward to seeing the cowl fettled and fitted.
