Author Topic: Special Hobby Lloyd C.V 1/48  (Read 39034 times)
Re: Special Hobby Lloyd C.V 1/48
« Reply #180 on: June 14, 2020, 03:27:54 AM »
Hi Stephen , Thank-you very much  :)
I'm rather pleased on how it turned out , better then on the HB D.1 .
Stage two is done . For the wings I used a dark brown pencil crayon over the straps covering the joining panels . Running the crayon on the top building this effect up . I didn't go heavy with this the painting stage will add more to this . On a few of the panels I made the odd knot and blended them in with a q-tip . The fuselage I used a light shade with the lightest shade picking out a the tail and up around the cowl . I can now start clear coating  :)
« Reply #181 on: June 14, 2020, 03:28:25 AM »
« Reply #182 on: June 14, 2020, 03:29:16 AM »
« Reply #183 on: June 14, 2020, 03:29:41 AM »
« Reply #184 on: June 14, 2020, 03:30:10 AM »
« Reply #185 on: June 14, 2020, 10:10:52 AM »
Clear coating is finished . I mixed Tamiya clear orange with Tamiya smoke , pre-shading is done with Tamiya smoke . This now needs to dry for two . It's damp and with many coat applied it's pretty thick ! It's darker then what the photo's are showing and this will come out more once the semi gloss is applied tying it all together , but it is looking good so far . Also sprayed the blue/grey using Tamiya XF82 Ocean grey 2 . Struts , landing gear , gun ring , tail skid , spinner . Work will start on the tail feathers next once the fuselage is dried . I still need to spray the rudder fin black for that stage . It really is starting to come together , fair amount to go yet .
« Reply #186 on: June 14, 2020, 10:11:19 AM »
« Reply #187 on: June 14, 2020, 10:11:46 AM »
« Reply #188 on: June 14, 2020, 10:12:12 AM »
« Reply #189 on: June 14, 2020, 10:12:39 AM »
« Reply #190 on: June 14, 2020, 10:13:04 AM »
Offline Radarman
« Reply #191 on: June 14, 2020, 12:28:12 PM »
More great progress, Terri. Is the plan to let the woodwork dry for two days?
        Kevin
Offline smperry
« Reply #192 on: June 14, 2020, 01:08:22 PM »
That ply is really looking good Terri. You seem to be perfecting the formula. (Which I plan on blatantly copying when it comes to my vac kit of the Fokker T.2)
sp
« Reply #193 on: June 14, 2020, 04:14:39 PM »
Stunning result Terri, looking beautiful already. Yes!!!!
« Reply #194 on: June 14, 2020, 10:28:07 PM »
Thanks for dropping by guys and leaving your kind feedback  :)
Kevin , yes that is the plan on letting the clear to dry for a few days . It's our rainy season right now so we get a lot of storms passing through leaving a lot of moister in the air taking longer for the paint to cure .
