Author Topic: Special Hobby Lloyd C.V 1/48  (Read 39139 times)
Re: Special Hobby Lloyd C.V 1/48
« Reply #150 on: June 06, 2020, 11:22:51 PM »
The PE in the back ground is Tom's Model Work PE German WW1 gun set in 48 scale . I have a few of these sets and in the British WW 1 guns . Have you tried these before ?
Thank you for the info. No, I never had a set or was aware of it. I just checked the Scalemates database and find more, but hard to find here in Europe.
« Reply #151 on: June 07, 2020, 12:41:50 PM »
Thanks Gary  :)
Frank , I  might be able to help you with that ...
I was able to get a bit of airbrushing done today . The wooden base colour is applied on both upper/lower surfaces . I used Tamiya Wooden Deck Tan and made a start on black basing the tail feathers . The next side will be sprayed tomorrow . For the next wooden shade will be a bit darking picking out different panels . More on this later when things dry ... I also finished drilling the struts for pins , just have to glue them in and finishing the rest of the details .
« Reply #152 on: June 07, 2020, 12:42:13 PM »
« Reply #153 on: June 07, 2020, 12:42:38 PM »
« Reply #154 on: June 07, 2020, 08:57:32 PM »
Excellent prep work Terri! I am looking forward to seeing the wood!
« Reply #155 on: June 08, 2020, 04:59:45 AM »
Making good progress Terri. The wood finish on your other models is first class - I expect this one will be too.
« Reply #156 on: June 08, 2020, 06:16:41 AM »
This is shaping up to be another great Terri build. Love the careful preparation you always do.
« Reply #157 on: June 08, 2020, 10:14:48 AM »
Thanks guys for the kind comments and for following along  :)
Okay , it turned out to be one lazy weekend in front of the bench . Raining all weekend and took in many naps ! ;) Got the pins fixed in place and and the rest of the clean up but that is as far as got . Turning my attention back to masking I sprayed the next shade of wood picking out every other panel using Tamiya Desert yellow . This should bring better constrat to the wood paneling breaking up the uniforum colour of just the one shade . With the rain we had this weekend it will take a bit longer for the paint to fully cure before the next stage ...graining  :o The other side of the tail feathers is also sprayed black and is set aside to cure .
« Reply #158 on: June 08, 2020, 10:53:38 AM »
The varying shades should make a great base for the wood tones Terri. I am looking forward to the next step.
« Reply #159 on: June 08, 2020, 05:48:24 PM »
Getting more interesting with each update!
« Reply #160 on: June 08, 2020, 09:35:11 PM »
Good progress, Terri.  It's coming together well.
« Reply #161 on: June 08, 2020, 10:22:42 PM »
This is going to look so sweet, Terri!  I can see that beautiful shiny mahogany looking like a Chris*Craft speedboat. ;D  Carry on!
Best,
« Reply #162 on: June 08, 2020, 10:41:16 PM »
Looking forward to seeing your wood grain effect now the base colours are down. It's going to look amazing!
« Reply #163 on: June 09, 2020, 02:38:36 AM »
With wood grain effect on those base coats the wings should look very different. Certainly worth the effort to break up a monotonous colour - it will look much more realistic.
« Reply #164 on: June 09, 2020, 09:50:03 AM »
Thanks guys  8)
I'm shooting for the same effect on the Hansa-Brandenburg D1 , or very close too it ..so on that note out comes the pencil crayrons  ;)
