Author Topic: Hobby Craft 1/32nd SPAD XIII times Three: plus Aviattic Luke  (Read 189862 times)
Re: Hobby Craft 1/32nd SPAD XIII times Three: plus Aviattic Luke
« Reply #390 on: June 07, 2020, 07:08:52 AM »
Bound to need a bit of touch up should work. I have no idea about correct colours but red would much better against the base coat. You need to convince Mrs G that you must have an early birthday present! ;)
« Reply #391 on: June 07, 2020, 07:14:29 AM »
I doubt she will be agreeable for a while. I have to take a trip to California on the 17th for My Sons Wedding in Folsom! An unexpected cost  8) It is a good thing that at least these numbers were correctly sized!
« Reply #392 on: June 07, 2020, 08:01:41 AM »
So, Less touch up than I had feared!
Offline Radarman
« Reply #393 on: June 07, 2020, 10:13:38 AM »
RAGIII,
Fine job on the mask for the number. What material did you use?
        Kevin
« Reply #394 on: June 07, 2020, 11:00:11 AM »
RAGIII,
        Kevin
Thanks Kevin. It was Tamiya tape, double layer for strength, placed on a board. Then the copy of the decal was taped over the Tamiya tape. I cut them by hand using a straight edge when possible. The wing number was totally done by hand.
« Reply #395 on: June 07, 2020, 12:04:16 PM »
Really excellent job on the " 2 " 's Rick . Most of the the top wing wing turned out fantastic !
« Reply #396 on: June 07, 2020, 07:58:13 PM »
That worked out very well Rick!
Offline Early Bird Fan
« Reply #397 on: June 07, 2020, 08:20:31 PM »
the numbers are looking great and all 3 together look superb  8)
« Reply #398 on: June 07, 2020, 08:56:54 PM »
Thanks Terri! I thought the one on the upper wing would be the hardest but it turned out to be fairly easy!
Thanks Richie!
Thanks for looking in and the comments!
One More:
« Last Edit: June 07, 2020, 11:06:59 PM by RAGIII »
« Reply #399 on: June 08, 2020, 05:03:33 AM »
Considering that those number masks were cut by hand I think that you can give yourself a very large pat on the back. Now I know who to turn to if I should need some letters/number masks cut in future....!
« Reply #400 on: June 08, 2020, 07:18:09 AM »
Thanks Stephen, Not sure I am the Mask Master but if things are sized right I can Muddle My way through  ::)
Today I ran a test on the Years Old Hobby Craft Decals( Thanks Mike Norris). The results were great so I went ahead with applying the Stork, Roundels, and rudder decals. I Must Say that I am Impressed with them. Opaque, adhere to detail, and tough!
PS: I am also pleased with the Match of red on My numbers to the roundels!
« Reply #401 on: June 08, 2020, 09:59:47 AM »
That looks like Guynemer's SPAD!  Great work Rick. ;D
Best,
« Reply #402 on: June 08, 2020, 10:55:36 AM »
Best,
Thanks Bob. Just need to apply the blue center and then seal all of the decals and paint work.
« Reply #403 on: June 08, 2020, 03:07:44 PM »
Looks brilliant, Rick!
« Reply #404 on: June 08, 2020, 09:33:30 PM »
Good job on the painting mask, Rick.
The red color does look like a good match with the decals.
This one's coming together nicely.
