Author Topic: SPAD XIII Esc 67 - get on with it!  (Read 23373 times)
Offline RLWP
  • Bodger
Re: SPAD XIII Esc 67 - get on with it!
« Reply #45 on: April 19, 2020, 07:22:50 PM »
This bit is an indulgence and doesn't fit my original objectives - so what. My model, my rules
The Hobbycraft radiator blinds are very basic:
The Eduard etch for the SPAD VII has a much nicer set:
And a radiator:
So, out comes the original:
The inside of the cowl had to be filed out a lot to make it the right size for the blinds. That left the question of how to support the radiator and blind
I had a piece of tube, so I turned up this:
The radiator sits inside on a step:
That's the original gear cover recovered from the original part
The blind sits at the end of the tube:
And it fits like this:
I'll straighten the blind when I do the final fit after painting
On with the show, the fuselage is stuck together ready for priming
What primer is safe for use with sprayed Humbrol paints? I have Halfords grey primer, the same in white and Tamiya white. Plus some 'Future/Klear/whatever it is this week'
« Reply #46 on: April 19, 2020, 11:45:13 PM »
Excellent idea on fitting the rad parts . Pit also looks super all button up !
« Reply #47 on: April 19, 2020, 11:54:49 PM »
Excellent Progress Richard! The radiator and shutters look great  8) I am Not sure I will be doing anything to mine but thanks for the idea!
Offline Pup7309
« Reply #48 on: April 25, 2020, 12:28:42 AM »
Really nice work. Pity WNW didn’t do a SPAD!
‘Not all who wander are lost‘
Offline petrov27
« Reply #49 on: April 25, 2020, 12:50:07 AM »
Looking really great!
All these SPAD builds are making me want to dig the old kit outta the stash and join in lol
« Last Edit: April 25, 2020, 04:55:45 AM by petrov27 »
-Patrick
« Reply #50 on: April 25, 2020, 01:18:25 AM »
Good work, as you say your model your rules. Got to enjoy it and it's going to look great.
Offline RLWP
  • Bodger
« Reply #51 on: April 25, 2020, 03:46:11 AM »
Any thoughts on Humbrol paints and primers? Anyone?
« Reply #52 on: April 25, 2020, 04:29:43 AM »
I am attaching the link to the WNW Salmson Directions. The colors should be the same.
http://www.wingnutwings.com/ww/productdetail?productid=3106&cat=4
PS: It looks like you are on your own on several of the colors  :-[
Offline RLWP
  • Bodger
« Reply #53 on: April 25, 2020, 05:19:29 AM »
OK, I should ask properly formed questions, shouldn't I
I have read on LSP that Humbrol enamels diluted with white spirit can react with some primers. Has anyone got any information on what primers I can use and what I should avoid?
« Reply #54 on: April 25, 2020, 05:47:57 AM »
Sorry about the misunderstanding. I should have known you had the colors of the Camo under control   :-[ As for your real question I have No Idea...Sorry
Offline RLWP
  • Bodger
« Reply #55 on: April 25, 2020, 05:54:20 AM »
Oi! I'm responsible for that misunderstanding!!!
« Reply #56 on: April 25, 2020, 06:07:53 AM »
Sounds like a painting test is warranted.
Generally, you can put enamels on lacquers and acrylics on either one.  Make sure all coats of paint are gassed out well (dried) before painting over them.  Be very careful putting lacquers on enamels.  Some lacquers will 'craze' (wrinkle) a styrene surface.
So, I usually use Tamiya white primer (lacquer) first, then use enamels for color coats, then acrylics for weathering or protective coats for additional enamel coats.
I am not familiar with Hubrol products, so I can't speak to those specifics.  I believe most are enamels.
Many times I have to determine what kind of paint I'm dealing with by reading the label (a novel idea).   What is recommended for thinning or cleaning up can be a clue:  lacquers need 'lacquer thinner', enamels need 'paint thinner' (mineral spirits or white spirit), acrylics need water.
Sorry for the not-so-straight-forward answer and the lesson in paint chemistry (which you probably already knew), but I think a paint test would be the best way to go.
Offline RLWP
  • Bodger
« Reply #57 on: April 25, 2020, 06:21:33 PM »
Thanks Ken, there are enough clues and hints in your post for me to proceed
Offline RLWP
  • Bodger
« Reply #58 on: April 26, 2020, 06:57:39 PM »
I did my patch test and all is well
I'm priming the SPAD as we speak
« Reply #59 on: April 27, 2020, 03:19:52 AM »
Good man!
