Author Topic: WnW Sopwith Pup  (Read 15338 times)
Re: WnW Sopwith Pup
« Reply #60 on: May 20, 2020, 10:10:37 AM »
Very nice indeed !  8)
Online lone modeller
Re: WnW Sopwith Pup
« Reply #61 on: May 21, 2020, 03:51:44 AM »
Super detail on the undercarriage.
Re: WnW Sopwith Pup
« Reply #62 on: May 22, 2020, 05:25:09 AM »
Thanks Bjarne, Rick, GazzaS, Richie, Terri and Stephen! Your support is very much appreciated!
You might have seen that I didn't use any micro tubing with that turnbuckle on the undercarriage. I didn't really want anythin like that there, even though I've been shopping at Bob's Buckles superstore, so I simply twisted the monofilament and added some super glue. Looks good I think.
Rigging is on its way + some small additions like the machine gun... first a hole lot of eyelets were installed, but only at one end of each wire this time. I thought I'd try and do without the eyelets on the bottom wing. I know that they won't be very visible in the end, but I thought that just a piece of Bob's micro tubing would look more like a terminal that an eyelet and a piece of tubing. Maybe it wont make any difference at all?!
This means however that there are a lot of lines glued straight into the different attachement points in different places. So it's a hairy Pup right now...
Some places needed specially made terminals. This is for the wires going from the underside of the tailplane to the very end of the fuselage. I simply used a flatnosed plier to crimp the middle section of a piece of 0,5mm tubing and then glued it to the underside.
The same method was used for the attachement point on top of the fin. Only here I used a ruler to push down on the piece of tubing, as I needed a narrower centre section. It was then drilled through and attached on that piece of copperwire you can see.
Last thing  for today was to arm the aircraft. First some ammunition for the machine gun and then attaching the gun to the aircraft.
Tomorrow I will start with the cross bracing wires. I had to paint up some more monofilament first. It's drying now.
Take care!
Re: WnW Sopwith Pup
« Reply #63 on: May 22, 2020, 05:38:26 AM »
Nice work, so this will end up as a great looking Pup!
On your good macro pictures the WNW model shows nice details, very impressive! I can only dream of those in 1/48.
Re: WnW Sopwith Pup
« Reply #64 on: May 22, 2020, 08:32:37 AM »
I don't know where to start so I will just give this an Overall Incredible Detailing!
Re: WnW Sopwith Pup
« Reply #65 on: May 22, 2020, 10:05:39 AM »
Neat solution for the tail rigging and beautiful job on the Vickers ! :)
Re: WnW Sopwith Pup
« Reply #66 on: May 22, 2020, 05:31:09 PM »
Great work Fredrik,your rigging ideas look pretty perfect. The precision painting of the brass on the Vickers is amazing, love the ammo belt too.
Re: WnW Sopwith Pup
« Reply #67 on: May 23, 2020, 08:35:38 PM »
That looks very nice!
Re: WnW Sopwith Pup
« Reply #68 on: May 23, 2020, 08:49:17 PM »
This is progressing very nicely Fredrik.  A splendid Pup is emerging!  Very well done.
Best regards,
Re: WnW Sopwith Pup
« Reply #69 on: May 24, 2020, 06:28:18 AM »
Thank you everyone, for your continued support! Very much appreciated!
Long weekend here in Sweden and even though we aren't in lockdown we're supposed to stay socially distant which leaves a lot of time to model... and there was rain and clouds today...
Rigging is on the home stretch now... here are some pictures. New camera setting as I thought previous pictures a bit dark.
All rigging lines prepared. You really got to keep track of loose ends here.
Attaching the upper wing was a lot easier on this model than on my WnW Albatros D.V! And it's beginning to look good!
And then I spent hours finalising the rigging. A few mishaps on the way, but all managable in the end. I will have to go back and touch up the paint on the wires, but that's probably not visible here, and I will paint the micro tubes aluminium later on.
Tomorrow it might get onto its legs...
Take care! /Fredrik
Re: WnW Sopwith Pup
« Reply #70 on: May 24, 2020, 11:48:49 AM »
Amazing work on the rigging and anchor points! Looks Superb!
Re: WnW Sopwith Pup
« Reply #71 on: May 29, 2020, 06:01:54 AM »
Well, she's finished! A pleasant build and isn't it fantastic how a simple green box of an aircraft can be really beautiful!? I am actually really happy about how this turned out! More pictures will eventually show up in the completed section.
Thanks for the support along the way and thanks for looking!
Re: WnW Sopwith Pup
« Reply #72 on: May 29, 2020, 06:22:13 AM »
Gorgeous Results in all ways!
Re: WnW Sopwith Pup
« Reply #73 on: May 29, 2020, 06:22:37 AM »
Beautiful work Fredrik, it's been a real pleasure to follow this build.
Re: WnW Sopwith Pup
« Reply #74 on: May 29, 2020, 06:45:26 AM »
Love it Fredrik!
And every little detail... superb. I particularly like the oil staining on the firewall.
