Author Topic: CSM Rumpler 6.B1 float plane  (Read 18606 times)
Re: CSM Rumpler 6.B1 float plane
« Reply #60 on: December 27, 2019, 11:26:58 AM »
 :) Up-date started end on page 4
« Reply #61 on: December 27, 2019, 10:39:46 PM »
This looks like it would be a difficult plane to get in and out of, with the cabane strut behind the cockpit.
(And its sooo small  ;D)
« Reply #62 on: December 27, 2019, 11:57:54 PM »
Great progress Terri! Excellent prep on the rigging!
Offline Radarman
« Reply #63 on: December 28, 2019, 12:36:36 AM »
Looking good Terri. What is the material you are using for the rigging? It looks metallic in the photo.
                                                       Thanks and keep up the great work,
        Kevin
« Reply #64 on: December 28, 2019, 10:59:45 AM »
Hi Ken , Rick and Kevin . Thanks guys for the continuing support on this build . It is really needed with this one .
Ken , it's even worse with the top wing in place ...it's like the monkey bars at the local playground .
Kevin , I'm using smoked invisible thread ( mono line ) I pick this up at one of the local fabric shops about 15 years ago it was around 6 bucks for it , but there is MORE than a lifetime supply ! You can get it clear as well . The clear can be pick up at the dollar store or buck or two . ( spool in the background of photo )
After spending a few hours the top wing is now mounted and the struts in place . I only had to shorten one strut from the twist in the wing . With all the wrapping of the parts I tried my best to get everything line up and straight in relation to that warpage . I total missed making the bracing struts for the tail planes so I will do this when I rig up the flight controls  ::)
This will set over night to dry up more ....the rigging begins .
« Reply #65 on: December 28, 2019, 11:00:11 AM »
« Reply #66 on: December 28, 2019, 11:32:40 PM »
Impressive T! Looks fantastic "Resting" on the floats!
« Reply #67 on: December 29, 2019, 03:23:05 AM »
Thanks Rick ! :) Fingers crossed that the struts for the floats go well . I really haven't done much test fitting with this so I'm hoping that it doesn't come back and bite me in the ass .
« Reply #68 on: December 29, 2019, 07:20:21 AM »
Terrific work on this little gem, Terri. Hats off to you for the work you've done and how well it's looking so far. Following this one closely.
Offline Robin
« Reply #69 on: December 29, 2019, 10:01:07 AM »
Yeah...I like it also.
Something in between a low rider and Thumper feet. ;D
Looks great already T.!
Robin  :)
« Reply #70 on: December 30, 2019, 05:29:11 AM »
Thank you Gary and Robin ! :)
After inventing a whole new language during the rigging of this bi-plane .( Had a few lines break and one I had to redo three times !) The main rigging is now done and can move on the the floats .
« Reply #71 on: December 30, 2019, 05:29:41 AM »
« Reply #72 on: December 30, 2019, 08:17:07 AM »
    Gotta say Terri, you've tamed this handful of a beast rather well! The strut layout makes the top wing addition look like a real challenge and the rigging appears anything but simple. I can see why it was on the shelf for a while but it's almost there, and looking very nice!
« Reply #73 on: December 31, 2019, 12:11:17 AM »
Outstanding rigging as always Terri!
« Reply #74 on: December 31, 2019, 11:05:58 AM »
Howdy Lance ! Taming the beast is an understatement . I don't know why I punish myself so and wonder if I'm actually crazy enough to continue down the rabbit hole , but I could only come up an answer that's fitting ...dame rights I'm chasing that rabbit !!!
Thanks Rick , must say though a little out of shorts with rigging in 48 scale . Got used to rigging in 32 scale . Fingers don't work the same like they used too .
