Author Topic: Macchi M-5  (Read 64753 times)
Offline Europapete
Re: Macchi M-5
« Reply #255 on: March 30, 2020, 03:54:45 AM »
excellent job Mike, and thank you for sharing your technique. I am sure we will all make good use of that. Regards, Pete in RI
Re: Macchi M-5
« Reply #256 on: March 30, 2020, 05:15:42 AM »
Slight change of plan regards the upper wing roundels.
My intention was to mask and paint the roundel outer green and inner red only, leaving the applied CDL and rib tapes showing where the roundel white inner circle would have been.
However, with a CDL decal layer and rib tape decals over that, I found that even with two sealing coats, the masking started to lift the decals from the wing surface.
I was able to remove the paint with thinners as I'd given the CDL decals two coats of sealer, so that prevented the thinners attacking the decals.
So plan B - first apply the kit decals, despite the fact the inner ring is too white for my liking.
Actually as the decals are translucent, they do allow 'see through' of the wing rib tapes and spar, which is a bonus.
Then cut a 'white' ring from the CDL decal sheet and apply it onto the white roundel ring, which will tone it down and match more closely the surrounding CDL.
Then I can apply the CDL rib tapes and hopefully highlight the covered wing spar with a pigment dusting - we'll see.
The 'ghost' roundels I'll create on the underside of the upper wing will be masked and painted, as the CDL decal and rib tapes need to be applied over the roundel.
This shot is the basic kit roundel applied and before the CDL inner ring is added.
« Last Edit: March 30, 2020, 06:41:28 AM by Mike 'Sandbagger' Norris »
Re: Macchi M-5
« Reply #257 on: March 30, 2020, 07:20:51 AM »
Excellent!
Offline Dave Brewer
Re: Macchi M-5
« Reply #258 on: March 30, 2020, 11:29:02 AM »
Gee Mike,this is not the smoothest build,your tenacity and adaptability to the issues is quite inspiring,I've decided to get on to a couple of shelf of doom projects when I complete my 2 current ones;thanks for the motivation.
Dave.
Re: Macchi M-5
« Reply #259 on: March 30, 2020, 06:24:01 PM »
Thanks guys.
Dave:
Yes the last four models of mine have all had their issues, either from the basic kit or of my own doing (modifying, correcting etc).
This one is no exception, but as we say 'we're modellers, not kit builders'.
Offline RLWP
  • Bodger
Re: Macchi M-5
« Reply #260 on: March 30, 2020, 09:27:10 PM »
I like that one
Re: Macchi M-5
« Reply #261 on: March 31, 2020, 02:16:28 AM »
I think that's as far as I can take the top roundels.
Moving on now to the undersides of both wings.
That means red and green outer areas with CDL centre sections and 'ghost' roundels' under the upper wing.
Offline Europapete
Re: Macchi M-5
« Reply #262 on: March 31, 2020, 07:07:36 AM »
Kind of after-the-fact I know, but would it have been feasable to cut the white ring out of the decal and just apply the red and green? regards, Pete in RI
Re: Macchi M-5
« Reply #263 on: March 31, 2020, 08:18:29 AM »
Yes I had considered trying that.
To accurately cut out the white ring from the roundel decal would require a circular cutter.
I have a 'thinnerline' circle cutter, similar to the 'DSPIAE' circle cutter.
However cutting the ring out of the roundel would doubtless cause the decal to chip or tear.
Also it would have been extremely difficult to centre the cutter accurately over the centre of the decal to achieve an accurate circular cut.
Lastly, once one cut had been made, you'd end up with two separated decals, which would make it very difficult to make a second circular cut to leave just the green ring and the red centre disc.
Instead I applied the whole decal to the wing - CDL decal sheet taped down on cutting mat - engineers square taped down to act as aligner for the cutter - first cutting the centre (red) disc, followed by cutting the outer edge of the ring. Each cut was tested first on paper until the correct size was set.
Re: Macchi M-5
« Reply #264 on: April 01, 2020, 12:11:58 AM »
Whatever the method used you have achieved terrific results!
Offline Europapete
Re: Macchi M-5
« Reply #265 on: April 01, 2020, 05:45:49 AM »
Certainly has. And congrats on the contest wins I read in the GWSIG newsletter.
Re: Macchi M-5
« Reply #266 on: April 01, 2020, 07:40:15 AM »
Thankyou  :)
Re: Macchi M-5
« Reply #267 on: April 01, 2020, 09:21:22 AM »
Hey Mike , the rundels turned super ! Very nice effect , most impressive  :)
Offline AndRoby67
Re: Macchi M-5
« Reply #268 on: April 01, 2020, 07:55:18 PM »
A big amount of surplus work, you're sure a great modeller.
My mouth is still open...
Roberto
Re: Macchi M-5
« Reply #269 on: April 01, 2020, 08:22:52 PM »
Many thanks.
I've nearly completed the wings, so I'll post up some shots later today,
