Author Topic: Macchi M-5  (Read 64714 times)
Offline RLWP
  • Bodger
Re: Macchi M-5
« Reply #135 on: January 29, 2020, 07:08:28 PM »
Looking good, Mike, and well worth the effort
Re: Macchi M-5
« Reply #136 on: January 29, 2020, 07:50:53 PM »
Splendid work!
Carry on...  :o
von B
Re: Macchi M-5
« Reply #137 on: January 31, 2020, 06:46:30 AM »
Those details are coming along great  :)
Yep!
Re: Macchi M-5
« Reply #138 on: January 31, 2020, 07:26:45 AM »
Just a quick update for the engine modifications.
The valve operating gear is now done - made from 0.2 mm and 0.5 mm thick plastic card..
The shots below show the dry fit of:
Carburettor and induction manifolds
Ignition lead support tubes
Coolant supply and return pipes.
All that's left now are a couple of external oil pipes and it should be ready to start painting and building the engine.
Other items such as ignition leads, engine placard plates etc can't be added until the engine build is completed,
Offline RLWP
  • Bodger
Re: Macchi M-5
« Reply #139 on: January 31, 2020, 07:37:55 AM »
That is looking much more like a Isotta Fraschini, Mike
Better leave the top wing off so people can appreciate the engine  ;D
Re: Macchi M-5
« Reply #140 on: January 31, 2020, 07:46:46 AM »
Absolutely amazing work on your engine, Mike.
Re: Macchi M-5
« Reply #141 on: January 31, 2020, 07:58:20 AM »
Incredible detail on that engine Mike, looks functional.
Re: Macchi M-5
« Reply #142 on: January 31, 2020, 11:26:55 PM »
I've added the external oil pipes at the propeller end of the engine.
These made from 0.7 mm and 0.4 mm brass tube,
Re: Macchi M-5
« Reply #143 on: February 02, 2020, 01:36:54 AM »
More incredible detail!
Re: Macchi M-5
« Reply #144 on: February 02, 2020, 12:00:57 PM »
I'm going to say ....eye candy !
Re: Macchi M-5
« Reply #145 on: February 04, 2020, 04:04:20 AM »
Two pipes were connected to the underside of the coolant return pipe, located at the top of the engine.
The two pipes were routed across to the other side of the engine, between the end and centre cylinder banks.
The purpose for  these two pipes is not clear or to where on the engine they were eventually connected.
As the pipes were connected to the coolant return pipe, it would seem hot coolant from the engine was carried in the pipes.
My only assumption is that these pipes supplied hot coolant to the housings of the two carburettors, thereby ’pre-heating’ both of the carburettors.
This would have helped preventing icing up, which may have been more of a problem for seaplanes more than land based aircraft.
The pipes were made from 0.8 mm and 0.5 mm diameter tube.
Re: Macchi M-5
« Reply #146 on: February 05, 2020, 12:46:40 AM »
The Details just keep getting better!!
Re: Macchi M-5
« Reply #147 on: February 05, 2020, 08:07:37 AM »
I've gone as far as I can modifying the resin kit engine to better resemble the actual 'Isotta Fraschini V4B’ engine.
The shots below show it primed and dry fitted, including replacement exhaust pipes made from 1.4 mm diameter tube.
It's the longest engine modification I've undertaken thus far, but hopefully it'll be worth it.
So now, it's time to move onto modifying the cockpit area !!
Offline RLWP
  • Bodger
Re: Macchi M-5
« Reply #148 on: February 05, 2020, 06:45:28 PM »
It looks well worth it to me!
You seem to use small diameter tube in places where I use copper wire, is there any particular reason for that, Mike? I use copper wire because you get lots on a reel for not a lot of money
Re: Macchi M-5
« Reply #149 on: February 05, 2020, 06:50:21 PM »
Amazing details, Mike  :o
Bring on those cockpit mods.
