Author Topic: WnW Albatros, Ltn Wolf, Jasta 5  (Read 25464 times)
« on: October 20, 2019, 07:35:15 AM »
While I keep working on my two test models - the D.III and D.V in 1/48 scale - I did take out my third semi-built Albatros. The idea with this one was to utilise the lessons learnt from the other two as well as any other good ideas borrowed from places like this forum, but having looked at it again I realise that I need some tips and advice to get it past the finish line... first some pictures from the build so far.... actually quite a few pictures, so I'll post a few at the time - internal wood first.
I really like the look of the Albatros, so therefore I got Wingnut's Jasta 5 trilogy when it came and the first build was set to be Leutnant Wolf's aircraft with the blue and white diamonds.
First try on the internal wood. I was a bit lazy and thought that I could leave the ejector marks. I later realised that that was a bad idea and scraped them off.
Some other pieces of wood, most of which will never be seen but with which I'm really happy. At the same time I suppose that the woodgrain is a bit out of scale.
Next time some other bits and pieces from the inside.
Re: WnW Albatros, Ltn Wolf, Jasta 5
« Reply #1 on: October 20, 2019, 04:02:16 PM »
Good morning!
Some more pictures. Fuel tank and ammunition bins.
Cockpit done. I used Uschi's leather decals for the seat. I can probably improve on my technique using them, but it turned out ok. The kit seatbelts - can they be fitted?! I couldn't manage that as long as the crosswise belt was on, so I ended up cutting it away to have two separate shoulder straps.
And everything installed.
« Reply #2 on: October 21, 2019, 03:01:09 AM »
Excellent work on all of the interior! I had the same issue with the belts. I had a spare set from an old build that worked perfectly.
Offline AlbertD
« Reply #3 on: October 21, 2019, 08:15:06 AM »
Looks great so far. The wood is excellent. Is it done with oils?
« Reply #4 on: October 21, 2019, 08:35:48 AM »
Your wood grain did come out good.  I am glad to see you addressed the ejector pin marks.  If they are deep, I fill them with thick CA glue to make quick work of them.  The leather seat looks fine.
« Reply #5 on: October 21, 2019, 10:06:21 AM »
Looking good Fredrik.   :D
Offline scott362
« Reply #6 on: October 22, 2019, 05:41:55 AM »
I will be watching this one with great interest, I have Rowan's set for Ltn Wolf but have not been brave enough to use them yet.
« Reply #7 on: October 22, 2019, 10:51:41 AM »
Following along on this journey  ;)
« Reply #8 on: October 22, 2019, 05:14:44 PM »
Thanks Albert! Yes, it is. It's a long while since I did it though, so I don't really remember what base colour and oil colours I used. My guess would be Gunze Radome or Sail for the base colour and the oils a mix of burnt sienna and something lighter than that. Ohh, the engine bearers must have a darker base colour... I think.  :P/F
« Reply #9 on: October 22, 2019, 05:16:09 PM »
Thanks! I'll try the CA on the next ejector pin mark I come across. Promise! /F
« Reply #10 on: October 22, 2019, 05:21:40 PM »
Thank you Juan, Scott and Terri! It feels good to have you on board!
Scott - I only have the kit decals and I'm sure Rowan's decals might be better, but there are other possibilities... wait and see. /Fredrik
« Reply #11 on: October 22, 2019, 05:37:07 PM »
Work on any kind of model has been slow so I'll keep posting some images of the work previously done on this one. We are slowly approaching the stage where I'm stuck at the moment... Engine pictures this time.
Ok, there are a few non-engine related bits and pieces here, but this is my usual approach to priming and painting.
The plane is going to have the engine closed up later, but I took the opportunity to detail a little anyway. One of those sparkplugs might be visible... they are made of Albion Alloys tubes of two different sizes.
« Reply #12 on: October 23, 2019, 12:07:01 AM »
Very fine work on the power plant, Fredrik!
Offline Robin
« Reply #13 on: October 23, 2019, 03:59:02 AM »
Very nice job!
With a WNW D.v on the horizon for me...I'll follow this one with great interest. :)
Robin
« Reply #14 on: October 23, 2019, 04:37:17 AM »
That engine is super, the spark plugs are almost unbelievable!
