Author Topic: WnW Albatros, Ltn Wolf, Jasta 5  (Read 25607 times)
Offline Edo
Re: WnW Albatros, Ltn Wolf, Jasta 5
« Reply #15 on: October 23, 2019, 03:00:58 PM »
yes, the engine is really super!
well done!
ciao
edo
« Reply #16 on: October 23, 2019, 10:45:48 PM »
Very fine work on the power plant, Fredrik!
I agree with My Amigo 100%
« Reply #17 on: October 24, 2019, 06:38:53 AM »
Thank you all for your kind words... You did see that I forgot to remove that mold line on the copper pipe, didn't you?! :D
More pictures and now we move to fuselage and painting. Many of you probably know about the blue diamond pattern on Wolf's aircraft (otherwise you can see a drawing of it on the first picture in this thread, or google it) and here's my approach to that - no decals needed...
Fuselage closed and some areas masked off...
I had this idea that i would simulate the underlying wood, hence the desert yellow and the pencils in the picture. I believe someone else here might have provided the inspiration for that idea, can't remember who though. It turned out to be more or less a waste of time. After that everything was painted white.
Looking at the decals and pictures of the aircraft I realised that there are parallel ribbons going around the fuselage and that the diamonds are created from a sort of spiralling strand from front to back. So masks going around the fuselage where placed first.
After having marked the spacing at the rearmost and foremost masking I then placed the spiralling tape lengths - a lot of eyeballing involved in that... The forward and aft diamonds are, according to Wingnuts decals, not connected and therefore the slant of the masking is different.
And finally everything in between the thin strips of masking tape and anything else not meant to be blue was also masked off.
I'm still catching up with my own work, so everything so far was done a while back and that includes colour as well but you'll have to wait until tomorrow Swedish time anyway. Good night!
« Last Edit: October 24, 2019, 07:32:53 AM by FAf »
Offline Robin
« Reply #18 on: October 24, 2019, 07:18:23 AM »
The mummy of Albihotep V. :o
Robin  ;)
« Reply #19 on: October 24, 2019, 09:38:45 PM »
Amazing! I don't think I have ever seen anyone Mask and Spray this scheme! Looking AWESOME  :o
« Reply #20 on: October 24, 2019, 10:16:12 PM »
I must say, you are dedicated!
I have always believed that masking is an art in itself.
Looking forward to seeing this one in paint.
Offline nannolo
« Reply #21 on: October 24, 2019, 11:26:18 PM »
great job so far ...
I approve your decision to paint the diamon pattern. Surely it will give a better result
Ps you had the same idea and doubt ... if you can see the grain of the wood under the paint. I have yet to decide but it is also true that I have to use only the red color
« Reply #22 on: October 26, 2019, 06:36:07 PM »
Robin  ;)
 ;D Most of my builds end up as mummies at one point or another, or actually several times during a build. I am scared to death of overspray!
Thank you for your comments RAGIII, Kensar and Nannolo!
Why do I mask things rather than use decals?! Well, in part because I think decals bring with them their own difficulties and problems that can be avoided by masking instead. And in part because there is an immense reward waiting for you when you remove the masking and see the result. I firmly believe that masking isn't more difficult than using decals, but it might require more patience and preciseness. So I agree with Kensar saying that "masking is an art in itself", but remember that so is using decals.
Anyway... here are some more pictures...
Blue colour sprayed all around and then masking tape removed. I tried to save the masking tape as I use quite a lot of that thin rather expensive Aizu tape.
After that everything needs to be repeated as you only can mask every other diamond at the time. The tricky thing in this second phase is to place the tape exactly where it should go on the already painted diamonds. So masks, blue colour, remove masks... and success... almost...
This is when you discover that part about being patient and meticulous... and the main problem was that I know had to cover blue with white and that would mean a different white shade on some diamonds. But still, success I think!
So now we've almost cought up with the build. A few more pictures are waiting.
« Last Edit: October 26, 2019, 06:49:03 PM by FAf »
« Reply #23 on: October 26, 2019, 06:53:21 PM »
Oh, another mistake I had to correct was that I managed to place the masking tape on the wrong side in some places and that created too narrow and too wide bands of diamonds. That too had to be corrected. You can see the two wider bands, one just touching the overside of the wing attachment cut out and the other one two bands above that. /F
« Reply #24 on: October 26, 2019, 07:09:40 PM »
Great work! A very brave attempt and wonderfully executed. Hats off!
Offline Robin
« Reply #25 on: October 26, 2019, 07:19:44 PM »
Fantastic job!
Robin  :)
« Reply #26 on: October 26, 2019, 07:50:52 PM »
Picking up jaw off the floor, wow, you have the patience of a Saint.  Fantastic all around.   :D
Offline Gene K
« Reply #27 on: October 26, 2019, 10:36:06 PM »
Awe inspiring.
Gene K
« Reply #28 on: October 27, 2019, 12:10:55 AM »
You are Now the King of Diamonds  ;D Incredible results!
« Reply #29 on: October 27, 2019, 12:27:07 AM »
Well your efforts paid off rather well with the masking , well done  :)
