Author Topic: WnW Albatros, Ltn Wolf, Jasta 5  (Read 25518 times)
Re: WnW Albatros, Ltn Wolf, Jasta 5
« Reply #30 on: October 27, 2019, 12:44:10 AM »
Picking up jaw off the floor, wow, you have the patience of a Saint.  Fantastic all around.   :D
    I'll second that assessment! Earlier when you started this exercise I saw disaster in the making; to the contrary you've executed this beautifully! My sincere compliments, a very talented and beautifully executed demonstration of your modelling skills and a spectacular model in the making!
Offline AlbertD
« Reply #31 on: October 27, 2019, 01:26:56 AM »
Fantastic masking and painting. I can't even mask a simple strip without some bleeding.
« Reply #32 on: October 27, 2019, 02:00:42 AM »
Quite the masking job - and great results for sure.
« Reply #33 on: October 27, 2019, 02:57:57 AM »
I really love that picture! I do not expected such impressive great result, yaw dropping!
Really pitty for the small mistakes, I hope you will be able to recover them without to much effort.
« Reply #34 on: October 27, 2019, 03:27:21 AM »
Thank you all for your kind comments!!!
great job so far ...
I approve your decision to paint the diamon pattern. Surely it will give a better result
Ps you had the same idea and doubt ... if you can see the grain of the wood under the paint. I have yet to decide but it is also true that I have to use only the red color
I've decided against the idea that plywood woodgrain would be visible through anything but clear varnish in 1/32 scale. I'm also not good enough at making the woodgrain for it to look realistic in the first place. But that's just my opinion.
Don't worry Frank, I managed to sort it out. In the picture below you can see some extra white diamonds, they are the repainted ones. Though you might have to look hard. It's more visible in real life.
This is one paint job I find really tricky, to paint something white on top of a partially white background. I think you inevitably end up with different shades of white! I'll come back to this problem...
Offline Edo
« Reply #35 on: October 27, 2019, 03:41:52 PM »
it tourned out to be a beauty!
great paint job!
ciao
edo
« Reply #36 on: October 28, 2019, 08:05:24 PM »
Beautiful and impressive work. Outstanding!
Bye,
Offline AndRoby67
« Reply #37 on: October 28, 2019, 08:17:11 PM »
Hi!
Patience at higher level!
The result is outstanding!
I have same subject to build in 72nd scale, but I don't think that I will do the same....too little!
Great job!
Roberto
« Reply #38 on: October 29, 2019, 05:28:25 AM »
Awesome Fredrik!
That can’t be easy!
Offline Robin
« Reply #39 on: October 29, 2019, 06:14:39 AM »
For someone who thinks it's already an achievement to mask and paint a single fuselage band (me  :-[)...this is incredible.
Robin  :)
« Reply #40 on: October 29, 2019, 10:02:01 AM »
Those little errors add charm to the build you know ...Not a easy scheme to mask and you pulled it off pretty damn good Robin . I do have to ask though , do you still have hair left ?
« Reply #41 on: October 29, 2019, 09:25:25 PM »
Great job, Fredrik!  I agree with Terri - the small errors make it 'real'.  And makes it 'your' model.
« Reply #42 on: October 30, 2019, 08:19:59 PM »
I would also agree — if I could find any errors. A perfect paint job in my eyes, one to be really proud of!
« Reply #43 on: October 31, 2019, 03:32:50 AM »
Thank you Edo, Andreas, Kensar, Terri, Guy, Robin, Roberto and Manni!
Just to address some of your comments - masking like this isn't easy, but it's not difficult either. Patience is the key, but there are a few other smaller keys as well. One other key is that you need to be precise and still accept that it won't be perfect. I agree with Terri and Kensar about the "mistakes" adding character and personality. One should also remember that the real aircraft probably wasn't that perfect either. Imagine painting that pattern when you can't handle the aircraft and look at it from all angles!
Andreas; Thanks for reminding me to be pleased with the job. I am really proud of the work so far, but is there really such a thing as a perfect paint job?! Perfection is an illusion isn't it? And yet we strive towards it!  :)
Terri; I suppose it's my hair and not Robin's you're worried about...  ;) Mine is still in place, although I do worry about it from time to time. I also think that the problem comes as any build progresses. The longer you come, the more things will be destroyed if you mess something up. So maybe the hair will come off as I'm trying to fit the wings or do the rigging?!
Robin; There is nothing easy about fuselage bands. Very narrow masking tape and good eyes help! And if you can do one band, then you can do many and my paintjob here is really just a lot of single bands, right?!
Roberto; I dare you to try in 72nd scale! But I too think it might be just too small.
« Reply #44 on: October 31, 2019, 03:44:09 AM »
Last bunch of pictures before blog and build are at the same spot.
I like to paint as much as possible and think that markings, as a rule, should be painted on if it's possible.
I went with WNW's suggestion for the green on the tail. The red outline was sprayed using Tamiya's flexible 2 mm tape. First as a guide and then as masking inside that.
And now just a few different stages...
And now we have caught up! In the next post I've got some questions about how to move forward... tomorrow maybe.
Thanks for lookin in!
