Author Topic: Aviatik 'Berg' D.I  (Read 38112 times)
Re: Aviatik 'Berg' D.I
« Reply #90 on: November 03, 2019, 07:57:07 AM »
The figure looks good !
Online Mike Norris (UK)
« Reply #91 on: November 07, 2019, 02:07:46 AM »
Hi All,
The 'Aviattic' CDL decals have been applied to the under surfaces.
Weathering still needs to be applied,
« Reply #92 on: November 07, 2019, 07:30:58 AM »
The CDL decals and pre shading look Fantastic!
Offline Robin
« Reply #93 on: November 07, 2019, 09:25:00 AM »
Austrian pilot and CDL look great.
Can't wait (well, I can of course ;D) to  see this come together.
Robin :)
« Reply #94 on: November 07, 2019, 12:15:07 PM »
I like it !  :)
« Reply #95 on: December 18, 2019, 08:24:44 AM »
It's been a few weeks now since I last posted on this build.
I took two weeks out for a holiday break and this last week or so I've been fighting off a recurring cold (wide spread in the UK it seems).
However I'll be getting back to this build and the Macchi M.5 now.
« Reply #96 on: December 19, 2019, 07:58:13 AM »
The Aviatik 'Berg' D.1 was an aircraft that had many and varied camouflage schemes that were applied.
They ranged from plain varnished wood to streaking, sponged colours, solid colours joined by zig-zag borders and lozenge.
The Austro-Hungarian applied lozenge was much larger than the German equivalent and was either uniform shaped hexagons or 'squashed' hexagons.
This particular aircraft was manufactured by the 'Aviatik' Company, so had their standard uniform sized hexagon lozenge.
The decals supplied in the kit are not the best and have thicker than normal backing sheets.
Also they are not 'cookie cut' and need to be accurately cut out from the backing sheets.
They are thin and care is needed when applying them as they are easily torn.
I've primed the surfaces with white as this brings out the colours more accurately. 'Tamiya' Smoke was used (thinned 50/50 with X20a) to apply slight pre-shading before the decals were applied.
Here's the lower left wing as an example. Post weathering will be applied later in the build.
« Reply #97 on: December 19, 2019, 08:05:38 AM »
Looking good, Mike :-)
« Reply #98 on: December 19, 2019, 08:16:30 AM »
Great result with the tricky decals. Keeping on watching with great interest.
Offline Edo
« Reply #99 on: December 19, 2019, 04:02:03 PM »
that colour scheme is one of the ones i like best and it makes the Berg so iconic....
plus, you are modelling it in its full glory!
great results, indeed!
ciao
edo
« Reply #100 on: December 19, 2019, 11:47:50 PM »
The pre shading and lozenge application look amazing! Well Done!
« Reply #101 on: December 21, 2019, 09:21:23 AM »
The remaining Lozenge decals applied.
To say these particular decals were a challenge to apply would be an understatement!!
They are not cookie cut so have to be accurately cut out from the backing sheets.
The backing sheets are thick so extra soaking is required to release the decals.
The marks from the polythene bags they were delivered in (including a second set I had delivered) are still evident, although hopefully weathering and sealing coats will cover them.
The first set of decals (in the delivered kit) had small areas pulled away with the packaging.
The cut out decals for the ailerons, elevators and rudder were oversized and had to be trimmed to shape before applying.
The fuselage lozenge comes in 6 separate pieces (two for the fuselage sides, one each side of the fuselage rear decking (the faired 'hump') and one for each side for the tricky area between the fuselage side and base of the rear decking panel).
As you can imagine the lozenge hexagons need to be accurately aligned, but even so I found that I had to cut and add thin strips to the front of the fuselage sides decals, as they didn't reach forward far enough.
The colours for the lozenge hexagons for the two 'infill decals', between the top of the fuselage sides and the fuselage rear decking are different so can't be aligned and matched to the others
If the decals overlap anywhere you get the dark overlap due to double decals, so that need to be sorted where necessary.
Finally, as the carrier is very thin, they are prone to 'fold over' on themselves if you're not careful.
I think the only positives about these decals is that they are transparent so you can pre-shade before applying them (similar to 'Aviattic' clear backed decals) and they seem fairly robust when being applied.
Anyway, after the best part of the day, all of the lozenge decals have been applied.
There are a couple of small areas where the decals chipped etc, but weathering etc should render them less visible,
« Last Edit: December 21, 2019, 09:25:57 AM by Mike 'Sandbagger' Norris »
Offline Robin
« Reply #102 on: December 21, 2019, 10:18:15 AM »
despite the woes, the result is beautiful. :)
Robin
Offline Dave Brewer
« Reply #103 on: December 21, 2019, 02:55:10 PM »
Sounds like you had a trying day Mike,but the results are magnificent.
Offline Edo
« Reply #104 on: December 21, 2019, 05:49:43 PM »
‘magnificent” is the right word!
ciao
edo
