Author Topic: Aviatik 'Berg' D.I  (Read 38267 times)
Re: Aviatik 'Berg' D.I
« Reply #75 on: October 24, 2019, 04:15:43 AM »
Good work on solving the issues!
Those anchor points for the cross bracing, are they kind of common? Would for instance an Albatros D.V have anchor points in the same place?
« Reply #76 on: October 24, 2019, 06:27:41 AM »
Hi Faf,
The cross bracing on this aircraft was between the top of undercarriage front struts to the bottom of the of the struts.
However, as I had to heavily 'modify' the undercarriage assembly I could only fit the bottom bracing anchors to the outer edges of the axle fairing.
Certainly cross bracing was fitted to aircraft of WW1, sometimes only between the front undercarriage struts and sometimes between front and rear struts.
The Albatros D.v had cross bracing fitted but only between the rear undercarriage struts,
« Last Edit: October 24, 2019, 07:53:23 PM by Mike 'Sandbagger' Norris »
« Reply #77 on: October 24, 2019, 06:37:16 AM »
I've been working on preparing the wings, fin/rudder, ailerons, tail planes, elevators and their associated support struts.
The struts should, I think, have steel reinforcing pins moulded through them, but I found the 'Z' shaped cabane struts had ends without pins.
Also the fuselage indents for locating these struts had no locating hole.
The single piece fin and rudder had no locations for attaching it to the fuselage and neither did the tail planes.
The separate ailerons and elevators also has no locating pins/holes.
Therefore I added support pins of 0.6 mm diameter for the wing struts and ailerons and 0.4 mm diameter pins to locate the fin/rudder, elevators and tail planes.
« Reply #78 on: October 24, 2019, 06:41:42 AM »
Hi Faf,
Certainly cross bracing was fitted to aircraft of WW1, sometimes only between the front undercarriage struts ans sometimes between front and rear struts.
Thank you so much for your answer. I know I'm sort of stealing space here in your thread. So normally the anchor point would be on the actual struts... that makes sense I guess. /F
« Reply #79 on: October 24, 2019, 09:41:16 PM »
Continuing to be a lesson in Modeling Excellence!
« Reply #80 on: October 24, 2019, 10:20:22 PM »
I look at kits as just raw material to start with and embellish.  This kit clearly fits in that category and is a kit you have to build - not just assemble.
You are doing it justice, Mike.
« Reply #81 on: October 25, 2019, 06:38:17 AM »
On the top of the fuselage and to the rear of the radiator is a condensation matrix for cooling radiator steam back to liquid and returning it back into the cooling system through a pipe connected to the rear of the assembly.
Apparently this avoided a build up of steam pressure being lost through the filler cap and losing coolant.
Anyway I wasn't happy with the resin one piece part in the kit.
I felt it was too large at the base and anyway the top was slightly off centre with the bottom.
Also the kit doesn't appear to have the 90 degree pipe at the back of the assembly.
So I cut the part in two, re-shaped the base, connected them with brass tube and added the rear pipe using annealed 0.8 mm brass rod.
Strangely the photo-etch in the kit supplies only one 'matrix' disc for the condensation matrix, which presumably like a radiator, would have the matrix from front to rear?
I used the photo-etch from the front of the matrix (as that will be more visible) and drilled 0.3 mm diameter holes in the rear face to replicate the matrix,
« Last Edit: October 28, 2019, 07:37:35 AM by Mike 'Sandbagger' Norris »
« Reply #82 on: October 25, 2019, 11:43:55 AM »
most excellent Mike ! :) 8) 8)
« Reply #83 on: October 25, 2019, 12:02:00 PM »
Outstanding Mike, your details really shine.
« Reply #84 on: October 26, 2019, 12:21:40 AM »
Stunning work!
Offline UFAG
« Reply #85 on: October 26, 2019, 07:32:17 AM »
Getting along very nice..!!
« Reply #86 on: November 02, 2019, 05:03:31 AM »
Things are progressing slowly right now until I receive some decals I need.
I've applied small serial number decals to the struts and fuselage and painted the condenser assembly on the forward, top fuselage.
The fuselage underside has had wood decals (HGW Models) applied. Very thin and fragile!! Weathering and joint seams yet to be applied.
Tail skid painted and under surfaces pre-shaded and prepared for CDL decals.
In the meantime I'll crack on painting the figure,
« Reply #87 on: November 02, 2019, 09:20:57 AM »
Just catching up with this one - some absolutley superb details being added here. It may be a kit but you are turning it into a semi-scratch build with all of the extra details.
« Reply #88 on: November 03, 2019, 01:10:28 AM »
Really taking shape now. Looks Fantastic!
« Reply #89 on: November 03, 2019, 05:46:03 AM »
Austro-Hungarion pilot completed
« Last Edit: November 07, 2019, 02:18:11 AM by Mike 'Sandbagger' Norris »
