Author Topic: WnW RE.8 and Roland D.VIa  (Read 30531 times)
Re: WnW RE.8 and Roland D.VIa
« Reply #120 on: February 02, 2020, 11:48:19 AM »
Beautiful job on the wood effect , man that turned out sharp looking . Those figures are also impressive !
« Reply #121 on: February 02, 2020, 01:11:02 PM »
Thanks Terri!
« Reply #122 on: February 04, 2020, 11:21:44 AM »
With the top wing of the Roland now in place, the rigging is in progress. I'm using EZ Line and Uschi's "medium" line for the rigging, and RB Productions etched turnbuckles.
« Reply #123 on: February 04, 2020, 05:19:48 PM »
Beautiful work, the wood fits perfect to the nice lozenge! Great work at all.
Bye,
« Reply #124 on: February 04, 2020, 07:57:57 PM »
Wonderful work on the airplane and the figures!
« Reply #125 on: February 04, 2020, 09:11:30 PM »
Beautiful work!
Two questions if you don't mind. 1) Have you done anything to the turnbuckles except folding them? 2) How have you attached the rigging to the turnbuckles? Simply tied them?
Looking forward to the rest!
« Reply #126 on: February 04, 2020, 09:18:21 PM »
Lovely work all around.
vB
« Reply #127 on: February 04, 2020, 10:33:42 PM »
   8)
« Reply #128 on: February 05, 2020, 12:42:17 AM »
Looks even better as a Biplane! Lovely work!!
« Reply #129 on: February 05, 2020, 11:29:55 AM »
Oh my ....
« Reply #130 on: February 05, 2020, 01:47:26 PM »
Thanks again to all those that took the time to look at the photos and send a comment - all very appreciated!
Beautiful work!
Hello Fredrik, you ask a very good question. I used to just fold the turnbuckles and paint them, but realized some would open up and get diss-formed during the rigging process. Now I run a bead of cyano glue around the folded pieces which helps in that case. The rigging is attached to the turnbuckles by passing through the line and placing a drop of cyano on the join, then a careful cut the excess off with a brand new #11 blade. In the case of the turnbuckles that are part-way up the line (ie. aileron control cables) I cut off the one folded side of the turnbuckle, and pass the line up and through the holes of the turnbuckle (on the cut-off side) then secure the turnbuckle in place with a drop of cyano at the center after placing it in position. After painting it, highlighting with metalizer, and squinting hard enough, it should look ok.
I do try and fasten the wing-side turnbuckles to the model with a twisted piece of copper wire, making sure that the turnbuckle is free to swivel and line up with the eventual rigged line. There is nothing worse than having a rigged line with the turnbuckle not in alignment with it.
« Reply #131 on: February 05, 2020, 11:47:40 PM »
Gary,
    Your work on the Lozenge is simply outstanding, the tapes are especially well done as is the rest of the model. You are really exceeding your normally stellar performance on this one, beautiful work!
« Reply #132 on: February 06, 2020, 01:27:19 AM »
Gary,
Gosh, thanks Lance! Glad you approve. I always feel you're looking over my shoulder when I model...and try harder ;)  Always look forward to presenting my models to you at the next show (and of course seeing your masterpieces!).
« Reply #133 on: February 06, 2020, 05:51:20 AM »
Gary,
Gary,
   I'll look forward to seeing this and that beautiful "Harry Tate" in Edmonton early June I hope. I may enter a Fantasy Figure or perhaps  piece of Needle Point in lieu of aircraft if you're bringing work of this quality though, the "bar" has gone up dramatically with your recent pair!
« Reply #134 on: February 07, 2020, 07:31:00 AM »
One of the details it seems often ignored on the Roland D.VIa kit (judging from the "Customers Models" photos on the WnW website) is the control line for the radiator louvers, exiting the cockpit and going up into the top wing. In a couple of cases, photos show this to be a small link chain, and in one instance a simple piece of wire. I made one from photo-etched chain, and made a small port from styrene for the exit, just forward of the cockpit.
