Author Topic: AEG C.IV 1/32 Scratchbuilt Two Seater  (Read 32339 times)
Re: AEG C.IV 1/32 Scratchbuilt Two Seater GB
« Reply #15 on: November 07, 2012, 04:15:40 AM »
Hello Ken:
I am with Chris on this one.  I always found it interesting that people could scratch build a marvelous model.  I too will be following this to see how you progress.
Offline Galloway
« Reply #16 on: November 07, 2012, 05:58:48 AM »
Thanks Chris & Mark,
 Here is where I am today ......... right after taking this photo I screwed up the primer and had to strip the whole center section and re-tape..... just shot a light coat of primer again...... Might just strip it again and start over if I don't like the results...
 Thanks Again Guys!
  Ken
"Slàinte mhòr agad!"
« Reply #17 on: November 07, 2012, 07:43:36 AM »
You are making excellent headway with this build Ken, I really like your wing forming method, everyting is looking great so far.
Offline Whiteknuckles
« Reply #18 on: November 07, 2012, 01:50:09 PM »
Some great and interesting work there Ken.
Wings are looking good.
Watching this with much interest!!
Eternal Apprentice
Offline Galloway
« Reply #19 on: November 07, 2012, 05:03:21 PM »
Thanks Des & Andrew,
   Here is the center section with a coat of primer .... then I think I will finish the other side and the outer wing panels before all the sanding begins again...........
     Ken
« Reply #20 on: November 08, 2012, 01:40:26 AM »
Brilliant work on the ribs, Ken.
« Reply #21 on: November 08, 2012, 01:47:19 AM »
Looks like a kit part (thats a good thing cuz it means it is very consistent) Nice work so far!!
Offline Galloway
« Reply #22 on: November 08, 2012, 02:22:54 AM »
Thanks Bud & Steve ..... I'll try to get the rest of the upper wing panels taped and primed today.........
Offline Edo
« Reply #23 on: November 08, 2012, 11:26:38 PM »
Hi Ken!
your work is super!
One question: how did you get the shape of the wing profile such as this?
thank you
ciao
Edo
Offline Galloway
« Reply #24 on: November 09, 2012, 02:22:58 AM »
Hi Ken!
your work is super!
thank you
ciao
Edo
  Hello Edo,
        I would go with a little thicker piece of bass-wood and make a gauge out of plastic for the upper and the lower profile..... you could also make a sanding block in the proper profile shape to glue sandpaper on with Elmer's paper glue (works like a charm) .... again upper and lower profile... but the lower profile is the harder to manage because of the curve ..........
   Ken
Offline Galloway
« Reply #25 on: November 10, 2012, 03:30:42 AM »
Today's Progress........... tape cut and applied
« Reply #26 on: November 10, 2012, 03:52:00 AM »
Ken, your Dad would be proud!
Offline Galloway
« Reply #27 on: November 10, 2012, 07:24:16 AM »
Thanks Bud.... he may just be or at least tickled pink that I am giving it a go....
  Ken
« Reply #28 on: November 10, 2012, 08:50:13 AM »
The hard part is near completion by the looks of it. Very nice!!
Offline Galloway
« Reply #29 on: November 13, 2012, 04:35:56 AM »
Here is the latest...... after sanding the primer between the ribs I started adding the false ribs with tape..... the reason for sanding between the ribs and only in the direction of the airflow will be apparent once I spray a final coat of primer ...
  Ken
« Last Edit: November 13, 2012, 04:37:37 AM by Galloway »
