Author Topic: 1/32 WNW AMC DH.9  (Read 32042 times)
Offline Ryan
Re: 1/32 WNW AMC DH.9
« Reply #30 on: February 26, 2019, 10:54:15 PM »
Thanks Alistair, I'll prob leave the rivets alone, if I need to I can simulate with paint.
Worked some more on the fuselage, cleaning and test fitting...the upper forward cover needs quit a bit of work to sit level. Triming flash, widening locating slots and the like.
DH.9 by The 3rd Placer, on Flickr
Ryan
« Last Edit: February 26, 2019, 11:10:17 PM by Ryan »
Upcoming: Not sure!
« Reply #31 on: February 27, 2019, 01:19:20 AM »
Doesn’t look quite a click fit Ryan!
Coming along nicely though.
Offline Ryan
« Reply #32 on: February 27, 2019, 01:24:27 AM »
Thanks Guy, but I am horrified at those magnified shots showing rough primer.
It simply just does not look like that in person.
Having said that, will steel wool take some of that out with out scratching the surface?
Ryan
Upcoming: Not sure!
Offline krow113
« Reply #33 on: February 27, 2019, 04:04:31 AM »
Decent work going on here.
I use an MDC beading tool set to re-create and enhance rivets and rivet detail , a very good tool set.
Offline Ryan
« Reply #34 on: February 27, 2019, 05:10:33 AM »
Thanks Krow, I haven't done much yet,  ;D
Those rivets are very small, perhaps a set from Archer would work.
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #35 on: February 27, 2019, 11:19:59 PM »
I'm sorry to bring this up yet again, but I tend to fixate on certain things. (it's a problem I have)
This rough primer coat around the carb intakes just wont leave me alone. The Tamiya primer is a great product and I know how to use it.
While I was perusing the pics of this build I noticed the rough glare on this pic of the bare plastic...here enlarged.
Ruff by The 3rd Placer, on Flickr
Someone please put me out of my misery and tell me they see rough plastic too.  ;D
This would explain the rough primer job in this area and I can move on.
Thanks and sorry again.
Ryan
Upcoming: Not sure!
« Reply #36 on: February 28, 2019, 12:10:56 AM »
I can see it Ryan,
I would have assumed it was just intentional ‘texture’?
Offline Ryan
« Reply #37 on: February 28, 2019, 12:36:02 AM »
Maybe, its a little heaver on the right side than left, perhaps someone could check their kit.
Thanks Guy.
Upcoming: Not sure!
« Reply #38 on: February 28, 2019, 07:30:16 AM »
I can see it Ryan,
I tend to agree. I see it but don't see a major issue in the primed photos. I have seen some closeups of SE5as for example that are FAR from being a beautifully smooth finish. Of course that is JMHO.
Offline Ryan
« Reply #39 on: February 28, 2019, 08:02:43 AM »
Yes I need to move on.
Once base coat then clear etc. the finish should level out, till then my macro shots maybe a little rough!
BTW on the rivet restoration I might try those Archer rivet decals, I haven't decided yet.
Of course white glue drops may do the trick also since I need maybe 3 of them....hmmmm.
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #40 on: February 28, 2019, 11:10:49 PM »
Ok back to building.
First up was the job of replacing the buttons on the cockpit padding, the first pic is what you get out of the box...nice but hard to clean up.
DH9 by The 3rd Placer, on Flickr
Using the smallest punch I had I replaced the buttons, later after they dry I can reduce the height of them and make them more button like.
The last pic is a tip I'd like to share when cleaning up parts like the internal framework. If you use a set of locking tweezers you can custom cut strips of sand paper to reach almost anywhere.
OK done for now, the goal is to get some wood painting this weekend.
Ryan
Upcoming: Not sure!
« Reply #41 on: March 01, 2019, 03:06:49 AM »
Good tip Ryan,
I must get some of those.
Offline Ryan
« Reply #42 on: March 01, 2019, 03:34:49 AM »
Yes i have another one that has a pointed tip to really get in tight.
Probably my number one tool I use.
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #43 on: March 01, 2019, 04:04:24 AM »
Just was thinking what exactly are these buttons for?
The padding is secured on either side of the fuselage, so what are these for, would they be snaps for a weather tarp?
Ryan
Upcoming: Not sure!
Offline Gilly
« Reply #44 on: March 01, 2019, 08:50:49 AM »
Loving this build Ryan and thank you for the many tips included within it.
