Author Topic: Completed: scratchbuild 1/32 Hanriot HD.2 completed  (Read 50707 times)
Re: scratchbuild 1/32 Hanriot HD.2
« Reply #90 on: June 17, 2019, 12:59:37 AM »
Incredible detail work! Really looking terrific!
« Reply #91 on: June 17, 2019, 04:13:30 AM »
I have been away Ken and therefore just spent a very enjoyable time reading through and catching up. This is scratch building as Des would have done using a variety of materials and producing first class components and parts. This is better than WNW!
« Reply #92 on: June 17, 2019, 08:49:56 AM »
Ken , just simply stunning workmenship  all around . Looking forward on the next up-date .
« Reply #93 on: June 17, 2019, 11:00:51 PM »
An excellent update!!
« Reply #94 on: June 21, 2019, 10:59:00 AM »
Thank you again for the comments.
A small update - I made the wing struts out of coffee stirring sticks I found at work.  They were pretty even colored and have a tight wood grain that doesn't look too out of scale.  I laminated two together with superglue, which made them suitably stiff and then sanded to shape.   I drilled holes in the ends and glued soft wire into the ends.
A cherry wood stain brought out the grain nicely and a coating of Tamiya clear yellow will finish them off.  Since this picture, I have reshaped the trailing edges to a curve as they should be.
Weathered floats - I used pastel chalks which were easy to use and remove if I don't like the look.  I do like the amount of control this technique affords.
I hope they're not overdone.  The front access ports will be installed later, after everything is put together and I can determine the amount of weight to be added so the plane is not tailheavy.
Before I put the top wings on, I will finish the fuse details - a headrest pad and the covers that go on the sides of the guns.
Till next time...
Offline aliluke
« Reply #95 on: June 21, 2019, 04:00:04 PM »
 I haven't caught up on this until just now. Amazing work all round. Also love the colour scheme with the bird.
Alistair
« Reply #96 on: June 21, 2019, 05:57:00 PM »
Very effective look on the struts!!
« Reply #97 on: June 21, 2019, 08:53:20 PM »
Fantastic Ken, the wheathering on the floats is very nice...
Antonio
« Reply #98 on: June 21, 2019, 09:05:07 PM »
Ken , so far this is turning out to be a wonderful build to follow , those floats are awesome !
« Reply #99 on: June 23, 2019, 09:43:24 AM »
Thanks, everyone.
Here is a significant milestone - I have put the upper wings on.
But first - a potentially useful hint I picked up from building RC planes.  I have needed to make parts from sheet wood and needed to transfer line drawings to the wood as a pattern before cutting parts out.  Using a laser printed plan on paper, lay the paper printed side against the wood and apply acetone to the back of the paper.  I use a sponge for this.  Press firmly.  Then lift off the paper and the image has transferred to the wood.  This will only work once with a printed paper plan, by the way.  In this case, I used the image on the wood to make a form for the bulging covers that go over the machine guns.
Now that the educational part is over... the entertainment!
I likely will make the deadline on this one!
Online Juan
« Reply #100 on: June 23, 2019, 10:50:49 AM »
Wow, that looks fantastic.   :D  :D  :D
Offline aliluke
« Reply #101 on: June 23, 2019, 12:45:01 PM »
Wow indeed - beautifully made. Love the extreme rake of the struts - a very dynamic looking plane.
Alistair
Offline Edo
« Reply #102 on: June 23, 2019, 04:21:28 PM »
super!
Offline FokkerFodder
« Reply #103 on: June 23, 2019, 06:36:54 PM »
Brilliant work- love it. Cheers Matt
« Reply #104 on: June 23, 2019, 10:14:12 PM »
The struts came out great and your Hanriot looks Brilliant as a biplane! Amazing work all around!
