Author Topic: 1/32 WNW Albatros D.V Richthofen  (Read 38574 times)
Re: 1/32 WNW Albatros D.V Richthofen
« Reply #105 on: November 26, 2018, 03:13:32 AM »
Shame Ryan,
Despite that it really looks great. I love the controlled pin wash.
« Last Edit: November 26, 2018, 05:52:42 AM by Gisbod »
Offline Ryan
« Reply #106 on: November 26, 2018, 03:18:07 AM »
Ehh, it happens...nothing time and money can’t fix.
Upcoming: Not sure!
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #107 on: November 26, 2018, 06:51:42 PM »
HGW belts >> PE belts, good choice and this is relatively easy to repair. The HGW belts are mandatory for my builds nowadays, they are so much better looking then the PE things.
Think globally, act locally!
Offline Ryan
« Reply #108 on: November 26, 2018, 09:28:55 PM »
Thanks Ssasho0, should have used the HGW belts in the first place.
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #109 on: November 27, 2018, 11:04:33 AM »
Question on the HGW set, it just arrived....
Does one typical paint the buckles after assembly?
Follow up question, can you use a blackening agent on PE parts?
Thanks
Ryan
Upcoming: Not sure!
Offline Ssasho0
« Reply #110 on: November 27, 2018, 09:15:31 PM »
Thanks
Ryan
Blackening agent: just try it, I think you can use it.
painting: I paint them before assembly and then just touch ups afterwards if needed, but that just me.
Offline Ryan
« Reply #111 on: December 03, 2018, 12:42:25 PM »
The build continues with the repair of  self inflicted damage of the seat and backer. First up was a the fix of the right hand side seat support opening.
A punched disk was glued over the shaved down spot of the buggered original. The disk was drilled out to match the left one.
Red Baron by The 3rd Placer, on Flickr
After primer it looked like it never happened. :)
Last step was to repair, strip, and sand down the seat. New seat bracket rods were also created from (2) different diameter plastic rods, built long for trimming.
Ryan
Upcoming: Not sure!
« Reply #112 on: December 03, 2018, 11:51:01 PM »
Your repair looks fantastic. Looks as though you are back on track now!
Offline Ryan
« Reply #113 on: December 04, 2018, 01:43:44 AM »
Yes thanks, just enough to keep me in practice fixing things!
Ryan
Upcoming: Not sure!
« Reply #114 on: December 04, 2018, 02:17:10 AM »
Nice recovery Ryan, and hopefully smooth sailing from here on. Great Build and Log, I'm enjoying following your progress.
Offline Ryan
« Reply #115 on: December 04, 2018, 02:54:33 AM »
Good to hear Lance, glad someone is enjoying the ride.
Ryan
Upcoming: Not sure!
« Reply #116 on: December 04, 2018, 09:59:41 PM »
Just as an after thought Ryan,
To save scraping out the paint, I’ve found it works well to mask the ‘channels’ with a thin tape (@2mm), the ones I use for rib tapes. Much quicker, cleaner and effective. Just a thought for future builds!
I’m going to try to copy your ‘wet’ wood grain technique on my 1/48 SE5a, although it’s so much smaller with many protruding parts it may be tricky.
Can’t wait to see more updates.
Offline Ryan
« Reply #117 on: December 04, 2018, 11:29:07 PM »
Thanks for checking in Guy, you are correct about the tape, I was just impatient! :)
Play around with the wet technique, I should prob post a step by step on how to do it.
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #118 on: December 19, 2018, 10:53:12 PM »
I'm still in the fight with this one.  :D
After a brief rest period to cool off and fix my mistakes I have assembled the seat module and its ready for belts. Since I had to repaint the seat I tried a little shading to give a leather effect.
Not sure If I was successful but the dark edges around the seat was the result. I still need to pick out the areas of the seat frame in grey green.
Ready for Belts by The 3rd Placer, on Flickr
next update will be huge...wrapping up the interior.
Ryan
« Last Edit: December 20, 2018, 01:15:41 AM by Ryan »
Upcoming: Not sure!
« Reply #119 on: December 20, 2018, 09:09:15 AM »
All of the repairs look perfect as I said. The seat is excellent. Lookin forward to the interior wrap up!
