Author Topic: Hanriot HD1 1/48  (Read 12340 times)
Re: Hanriot HD1 1/48
« Reply #30 on: June 11, 2018, 03:17:42 PM »
Thank you Steve.
Changed my plan and set the upper wing before guns, it will need more attention but positioning will be easyer. An italian windscreen and half rigging done.
The resin turnbuckles look overscaled, will find something different for the next one...
« Reply #31 on: June 11, 2018, 03:39:24 PM »
Outstanding result, Giuseppe! Looking forward to the next update.
Offline aliluke
« Reply #32 on: June 11, 2018, 04:14:02 PM »
Just caught up on this Giuseppe. Really great work and I love the colour scheme plus decals. I'll keep a watch out now for updates.
Alistair
Stephane
« Reply #33 on: June 11, 2018, 05:18:47 PM »
Very nice work on this nice bird! Just few words about your rigging, because the tension created on our models is real, that' s much better to fix the rigging symetricaly. It seems to me that you stated by one side completely.
« Reply #34 on: June 11, 2018, 06:53:28 PM »
Very, very nice work!  A favourite of mine, your Hanriot is awesome.
« Reply #35 on: June 11, 2018, 08:07:08 PM »
Thank you all for cheching in and for your comments.
Rigging is made with EZ line, so I dare doing one side at a time, if using higher tension stuff will be imperative to proceed symmetrically and Stephane's advice is absolutely correct.
I noticed that this elastic thread tends to curl when in contact with cianoacrilate, has anyone suggestions to avoid this?
« Reply #36 on: June 11, 2018, 09:10:35 PM »
I seem to have missed this update earlier . Well Done! The rigging looks terrific!
« Reply #37 on: June 11, 2018, 10:20:37 PM »
Hallo Giuseppe,
I normally use EZ line, but the problem of getting curly when touching the CA glue is the same on all the elastic threads.
So normally I put a drop of glue on the eyelet after inserting the thread and then trim the "curly" thread remaining outside the eyelet.
I have now purchased Uschi's rigging thread and will experiment on the Breguet.
I also use to rig one complete wing at a time and never get that tension to unbalance the other side, as there are already struts that are glued to the wings to make the structure stiff enough.
What do you use as "resin turnbuckles"?
BTW I love the work you're doing on this plane!
« Reply #38 on: June 12, 2018, 07:18:46 AM »
Thank you, Richard and Antonio. I've been using resin "tensioner" made by quick boost, but the overall look is a bit overscaled. I think microtube sections will look finer.
Offline Iancshippee
« Reply #39 on: June 12, 2018, 09:51:53 AM »
Looking great! Nice execution of the camouflage on this one.
« Reply #40 on: June 14, 2018, 06:21:42 PM »
Thank you Ian.
I finished this first HD and pictures are posted in the completed models sections.
[/url]DSCN2904 by Giuseppe Brivio, su Flickr
DSCN2905 by Giuseppe Brivio, su Flickr
DSCN2907 by Giuseppe Brivio, su Flickr
« Reply #41 on: June 14, 2018, 06:59:35 PM »
I have enjoyed following your build. More in the completed Models section.
« Reply #42 on: June 14, 2018, 07:34:07 PM »
Really beautiful Giuseppe!
Online Juan
« Reply #43 on: June 14, 2018, 09:50:03 PM »
Spectacular Giuseppe, congratulations.
« Reply #44 on: June 14, 2018, 11:08:10 PM »
Thak you for visiting, and your comments.
