Under Construction
WnW Junkers D.1
Pages:
4
5
6
7
Topic: WnW Junkers D.1 (Read 28819 times)
Black Max 72
Full Member
Re: WnW Junkers D.1
Reply #60 on:
April 29, 2018, 09:37:00 PM »
Love the finish on those Spandaus. They look absolutely spot on.
Dave Rickard
Rockhampton QLD
GB
Full Member
Re: WnW Junkers D.1
Reply #61 on:
May 01, 2018, 04:31:39 PM »
Progress is a little slow at this stage as the wings need a fair bit of work to 'hide' the join lines along the leading edge thanks to the corrugated surface. It's do-able - just fiddly and time consuming. Starboard wing is on though - port is on the menu this evening after dinner....
GazzaS
Re: WnW Junkers D.1
Reply #62 on:
May 01, 2018, 05:39:03 PM »
Those Gaspatch guns are really great!
There are only two states to be in: Queensland and blotto.
Re: WnW Junkers D.1
Reply #63 on:
May 01, 2018, 11:09:20 PM »
Continuing to look awesome!
coyotemagic
Re: WnW Junkers D.1
Reply #64 on:
May 02, 2018, 01:11:53 AM »
Quote from: RAGIII on May 01, 2018, 11:09:20 PM
Have to agree with my Amigo, Gary! Awesome is the word that springs to mind!
GB
Full Member
Re: WnW Junkers D.1
Reply #65 on:
May 03, 2018, 06:15:30 PM »
Just about ready for the painshop....
pepperman42
Re: WnW Junkers D.1
Reply #66 on:
May 03, 2018, 10:14:19 PM »
Great build. Looking forward to the colour work!! Mine arrived yesterday.
Re: WnW Junkers D.1
Reply #67 on:
May 03, 2018, 10:58:03 PM »
Excellent! You are breezing through this one!
GazzaS
Re: WnW Junkers D.1
Reply #68 on:
May 04, 2018, 06:31:47 PM »
That's some of the best looking leather I've seen on model.
Gaz
Borsos
Re: WnW Junkers D.1
Reply #69 on:
May 04, 2018, 09:51:28 PM »
The plane itself is still not my cup of tea, but there's great workmanship all around this kit. Very nice!
Borsos
GB
Full Member
Re: WnW Junkers D.1
Reply #70 on:
May 05, 2018, 11:12:51 AM »
Thanks guys. Seat is just simply a red brown acrylic base with red brown oil paints gently 'stippled' on followed by a very light wash when dry.
Initially I was going to go for the all over alumimium scheme and while that would certainly be easier, I have changed my mind and will be doing the scheme on the box cover. Bascic colours are ready to go....
GB
Full Member
Re: WnW Junkers D.1
Reply #71 on:
May 05, 2018, 12:31:02 PM »
XF18 and XF1 are mixed as per instructions for the Light Blue undersides of the wings. Some tonal variation was also added by including a little more blue or white to the mix. When dry, two strips were masked off where the wings join the fuselage and painted white....
Gray
GB
Full Member
Re: WnW Junkers D.1
Reply #72 on:
May 05, 2018, 01:10:13 PM »
Leading wing edges are masked using Panzer Putty before the upper surfaces are sprayed with XF71 - white or black added for tonal variation...
GB
Full Member
Re: WnW Junkers D.1
Reply #73 on:
May 05, 2018, 03:12:09 PM »
After applying more putty, X16, XF52 and XF2 are mixed in equal amounts and applied via AB. The putty is used as the camo was applied by brush on the real thing so no soft edge demarkation lines....
GazzaS
Re: WnW Junkers D.1
Reply #74 on:
May 05, 2018, 07:15:23 PM »
Gary,
Your camoflage looks great. You know, you're the only person I've seen use Panzer Putty on a build blog besides me since I bought the stuff. Sometimes it's very handy.
Gaz
Pages:
4
5
6
7
Under Construction
WnW Junkers D.1
