Author Topic: WnW Junkers D.1  (Read 28757 times)
Re: WnW Junkers D.1
« Reply #90 on: May 07, 2018, 11:33:28 PM »
Just when you think it can't get any better, it does.  Great workmanship Gary.
Offline GB
Re: WnW Junkers D.1
« Reply #91 on: May 08, 2018, 01:24:18 PM »
What do you use as "a Future equivalent"? I haven't found the right stuff yet in NZ.
Alistair
Available at Bunnings.
Offline GB
Re: WnW Junkers D.1
« Reply #92 on: May 08, 2018, 01:25:48 PM »
Undercarriage and extensive rigging is added. Weathered with filters, washes and pigments....
Onto the prop next - finish line is in sight  ;D
Offline aliluke
Re: WnW Junkers D.1
« Reply #93 on: May 09, 2018, 06:44:57 AM »
This just gets better and better - I'd like a lesson from you one day on using filters and washes!
Thanks for the tip on "Future" I'll give it a try. Do you air brush it on?
Alistair
Offline RLWP
  • Bodger
Re: WnW Junkers D.1
« Reply #94 on: May 09, 2018, 08:02:40 AM »
8)
Managed to grab a little bench time this evening and fitted the MG mounting cradles and pipework (not sure what it's actuially for though?).
The central one is the sheathed cable to the tachometer (rev counter). The two outer ones are the sheathed cables to the trigger motors on the guns*
This is an lMG08/15 with the trigger motor and flexible drive in place:
https://www.maximgun.de/deutschland/lmg-08-15/
The lMG and the Vickers both work in similar ways. Cartridges are drawn from the belt passing through the slot at the top, lowered and pushed into the breech. The cartridge is fired, the empty case is pulled out the breech, lowered and ejected through the tube sloping down to the left.
The trigger motor is the lump on the bottom of the casing with the flexible drive hanging down
The difference between the lMG08 and the Vickers is that the Vickers has the triggering mechanism turned upside down, so a Vickers has the trigger motor on the top:
Constantinesco trigger motor on top of case
There's a fascinating article here on rates of fire: https://riseofflight.com/forum/topic/30921-few-words-about-synchronizers-and-version-1026/
*you don't want to know they have flexible steel sheathing
Re: WnW Junkers D.1
« Reply #95 on: May 09, 2018, 08:29:55 AM »
Terrific use of filters and pigments. The piping looks great as does the gear.
Offline GB
Re: WnW Junkers D.1
« Reply #96 on: May 10, 2018, 04:26:35 PM »
Thank you for all the comments, feedback and encouragement. Am now calling this one complete as it goes into the display cabinet with the only other airraft nestled amongst all the armour! Will upload pics into the gallery after dinner...
Re: WnW Junkers D.1
« Reply #97 on: May 11, 2018, 12:18:47 AM »
Awesome Build! A pleasure to follow along with!
Re: WnW Junkers D.1
« Reply #98 on: May 11, 2018, 05:47:38 PM »
What a beautiful job!
Gaz
Offline Templar
Re: WnW Junkers D.1
« Reply #99 on: May 12, 2018, 12:01:32 AM »
Wonderful. I will start my D1 now and follow your example.
Thanks for posting
Re: WnW Junkers D.1
« Reply #100 on: May 13, 2018, 01:42:50 AM »
Excellent results!!  Thanks for the build log
Offline Dave in Dubai
  • Beyond the blue horizon
Re: WnW Junkers D.1
« Reply #101 on: May 15, 2018, 04:36:02 AM »
Great finish Gary,
Did you paint the prop or did you use an aftermarket wooden item?
Offline GB
Re: WnW Junkers D.1
« Reply #102 on: May 16, 2018, 05:55:57 AM »
Great finish Gary,
Prop is painted using home made masks, acrylics and oils.
Offline GB
Re: WnW Junkers D.1
« Reply #103 on: May 16, 2018, 05:57:27 AM »
Alistair
I find it brushes on the easiest.
