Author Topic: Bristol F.2B Fighter, Eduard 1/48, Update 7.3.2019 Rudder **FINISH**  (Read 58790 times)
Offline the great waldo
Re: Bristol F.2B Fighter, Eduard 1/48
« Reply #45 on: July 16, 2018, 06:45:28 AM »
Hi Frank
Thanks for the info.
« Reply #46 on: July 16, 2018, 06:18:32 PM »
Truly amazing and inspirational work!
Bristol F.2B Fighter, Eduard 1/48, Update 16.7.2018 Instrument Panel
« Reply #47 on: July 17, 2018, 06:05:08 AM »
« Last Edit: May 31, 2022, 01:14:37 AM by Bughunter »
Re: Bristol F.2B Fighter, Eduard 1/48, Update 16.7.2018 Instrument Panel
« Reply #48 on: July 17, 2018, 06:17:22 AM »
Brilliant Panel Frank!
« Reply #49 on: July 17, 2018, 06:58:28 AM »
As usual, I agree completely with my Amigo!  Brilliant!
« Reply #50 on: July 17, 2018, 06:09:27 PM »
Wow!  That IP is something else!
Gaz
« Reply #51 on: July 18, 2018, 04:17:37 AM »
Thank you RAGIII, Bud and Gaz!
Does someone noticed the strange mounting directions of the instruments?
I thought about and may be the reason is to have all needles up in normal operation, so the pilot can verify the actual values with a quick view. Clever solution 8)
« Reply #52 on: July 18, 2018, 04:36:09 PM »
Brilliant updates, and your micro additions are great as usual.
About the instruments I can conferm that is still a common practice to install with the dials oriented to have all the needles pointing the same direction with normal parameters, exactly as you suspected.
Bristol F.2B Fighter, Eduard 1/48, Update 23.7.2018 Undercarriage
« Reply #53 on: July 24, 2018, 05:57:57 AM »
« Last Edit: May 31, 2022, 01:14:48 AM by Bughunter »
Re: Bristol F.2B Fighter, Eduard 1/48, Update 23.7.2018 Undercarriage
« Reply #54 on: July 24, 2018, 06:40:21 AM »
Really awesome fix on the axle! You are an incredible modeler!
« Reply #55 on: July 24, 2018, 06:43:38 AM »
Incredible building Frank, you leave me speechless...
« Reply #56 on: July 24, 2018, 07:19:13 AM »
Frank, that is just spectacular work! I completely endorse Rick's comment, you are an extraordinary Model Builder, an "Experten"!! 8) 8) 8) 8) 8)
My sincere compliments!
« Reply #57 on: July 24, 2018, 07:04:03 PM »
That is really enviable work on those landing gear!
Gaz
« Reply #58 on: July 24, 2018, 09:16:44 PM »
Ditto. I'm amazed.
« Reply #59 on: July 25, 2018, 07:38:27 AM »
Thank you Rick, Juan, Lance, Gaz and Giuseppe!
And Lance: with your translation to german you surprises me :-*
To do this metal work with those brass pipes is pure fun and relaxing time for me.
