Author Topic: Bristol F.2B Fighter, Eduard 1/48, Update 7.3.2019 Rudder **FINISH**  (Read 58826 times)
Re: Bristol F.2B Fighter, Eduard 1/48
« Reply #30 on: July 07, 2018, 04:47:57 PM »
Simply amazing work Frank.
« Reply #31 on: July 08, 2018, 07:30:24 AM »
I join the enthusiastic comments
I have to say Thank you very much for all your enthusiastic comments, my friends!
Andreas sorry, no Stammheim next weekend :(
« Reply #32 on: July 09, 2018, 03:50:05 PM »
Stunning work, Frank. I admire your talent regarding those little details,
Bye,
Bristol F.2B Fighter, Eduard 1/48, Update 13.7.2018 RAF wires
« Reply #33 on: July 14, 2018, 08:47:06 AM »
« Last Edit: May 31, 2022, 01:14:14 AM by Bughunter »
« Reply #34 on: July 14, 2018, 09:07:03 AM »
Frank, you are no mere mortal.  Incredible work.....  :o
« Reply #35 on: July 14, 2018, 12:03:21 PM »
Frank,
    You are again exercising your pure magic on details, just incredible work and even more so in 1;48 Scale! I truly envy your soldering skills, I wouldn't be able to match this in 1:32 Scale. Great work and this promises to be a really outstanding model! 8) 8) 8)
« Reply #36 on: July 14, 2018, 07:55:51 PM »
Incredible work!
« Reply #37 on: July 14, 2018, 09:46:30 PM »
This is pure magic! I envy your sight and dexterity, you made real details in true scale. Chapeau!
« Reply #38 on: July 15, 2018, 03:51:20 AM »
Why can’t I see the photos Frank?  Sounds like everyone else can...  ???
« Reply #39 on: July 15, 2018, 05:31:23 AM »
Guy, I guess a iPad?
Try to load this URL in your address line, this is the address of the last picture:
http://drive.google.com/uc?export=view&id=1653MMJ3smRNVZZYq8kleCEwQAt4a7kIT
Some browsers seems not to load such pictures from Google into the page for some strange reason. If the picture loads then it is not a problem with access rights.
For me Firefox and Chrome are working, on the company machine also in MS Explorer.
Hope it helps,
Offline the great waldo
Re: Bristol F.2B Fighter, Eduard 1/48, Update 13.7.2018 RAF wires
« Reply #40 on: July 15, 2018, 04:15:46 PM »
Thanks Manni, if you love little details, you will love this update too!
RAF-Wires
Today I have some macros for my friends of micro mechanics!
This update handles the rigging with RAF wires. I will use the flat EZ-line, but I need some mounting. For the Brisfit I developed a new system, which combines ideas from my D.H.2 Stripdown and my Sopwith Pup.
At first I need 16 plates on the struts. A rest of a PE set drilled with 0,5mm, cutted, put on a drill shaft and soldered. For the risk of loosing some I added two more.
This pack was milled in form:
The size matches the parts of the CSM Dolphin, the wide finger is for the double wire.
The parts are separated. During the desolder I got some 4-parts pack, so I removed some fingers.
After that I added 0,5mm brass pipes. On the picture 52 drill holes are missing, done already. Unless I am very much mistaken the symmetric parts should match. Only the "flying wires" are double, the landing wires are singles.
To the strut the pipe is very short, just to keep a small distance.
The connectors made of 0,5mm brass pipe are in preparation, slotted and crimped. Some holes are missing. For the struts I need 52, 36 are done.
On the end I made a thickening of 0,7mm pipe, tinned and mounted with 0,2mm nickel silver. Only one prototype is done.
With a plugged strut it looks great. This mounts can be prepared and mounted with the struts. For the rigging I just need to plug in EZ-line and secure it with CA.
In 1:48 one can hardly find a more original solution?
With that preparation I hope to be able to finish the rigging task fast.
Now I just need to create some more pipes ...
Hi Frank
Can you please let me know what you used to put the slots in the tubing before crimping ?
« Reply #41 on: July 15, 2018, 05:58:00 PM »
Thanks Frank,
I can see them this morning on my phone.. maybe just the iPad?
Great work
« Reply #42 on: July 15, 2018, 06:04:00 PM »
Ps just looked at the work properly..
I’m lost for words.. I might as well take up flower arranging  ???
« Reply #43 on: July 15, 2018, 06:13:32 PM »
That is just amazing!
« Reply #44 on: July 16, 2018, 05:48:37 AM »
Thank you very much for your comments Juan, Lance, RAGIII, Guy, Giuseppe, Andrew and GazzaS!
I was born on this planet, but sometimes I wish to come from somewhere else to have more usable hands! Two are often really not enough ;)
Andrew, I use a etched saw from http://www.radubstore.com
I don't know, which one I bought. The blad is 0,08mm thin:
