Author Topic: Lozenge decals  (Read 2836 times)
Offline Stonewall34
Lozenge decals
« on: March 01, 2018, 12:00:42 PM »
What are the best and most affordable lozenge decals that are available out there.  Any suggestions will be appreciated.
Re: Lozenge decals
« Reply #1 on: March 01, 2018, 12:38:28 PM »
By a longshot - Aviattic
Offline Dave Brewer
Re: Lozenge decals
« Reply #2 on: March 01, 2018, 04:37:03 PM »
Absolutely,the Winx of decals.
Offline Ssasho0
    • Scale Models Club Bulgaria
Re: Lozenge decals
« Reply #3 on: March 01, 2018, 06:50:53 PM »
+1 Aviattic, they are by far superior to anything else on the market currently! You just have to decide if you want transparent ot the ones on white paper. The transparent gives you teh possibility to play with the underlaying colour and preshade the ribs etc. but they are a bit tricky and you may make them a bitdark very easy. The :white paper" version is not transparent so you can add efects only on top of them, which is no problem at all. Both lay down great and easily. I can only highly reccomend them!
Think globally, act locally!
Re: Lozenge decals
« Reply #4 on: March 01, 2018, 07:41:26 PM »
Absolutely Aviattic, they add so much to your model. But they are a bit different to apply on a surface. They are a bit like a plastic foil, Setting soloution doesn't work well on them. Best is a hair drier and patience. just follow their instructions, they supply you when you buy them.
Bye,
Re: Lozenge decals
« Reply #5 on: March 02, 2018, 01:14:34 AM »
Well, I have to COMPLETELY AGREE that Aviattic is the absolute best there is. Depending on the Aircraft type there are multiple choices as to 4 or 5 color, new or faded, blue, pink, loaenge,  or CDL rib tapes, and finally "Cookie Cutter" Versions. Research your chosen aircraft and look closely at the Aviattic store and Have Fun! As has been mentioned, FOLLOW DIRECTIONS  8)
Re: Lozenge decals
« Reply #6 on: March 02, 2018, 04:15:12 AM »
So many said it before, I can only agree: Nothing beats AVIATTIC!
Borsos
Offline Stonewall34
Re: Lozenge decals
« Reply #7 on: March 07, 2018, 01:36:35 AM »
Thanks guys,
Looks like that is what I will be going with.
Offline Stonewall34
Re: Lozenge decals
« Reply #8 on: March 07, 2018, 02:42:40 AM »
Another question:
How many aircraft will the lozenge decals do?
Offline aircare84
Re: Lozenge decals
« Reply #9 on: March 07, 2018, 07:42:12 AM »
In 1/32 scale, you get 1 aircraft per sheet. 1/48 is 2 I think & 4 in 1/72.
