Author Topic: Hansa-Brandenburg W.12 Early (WNW 1/32) ON HOLD  (Read 26339 times)
Online RAGIII
Re: Hansa-Brandenburg W.12 Early (WNW 1/32)
« Reply #15 on: January 20, 2018, 11:36:18 PM »
I like the subtle wood effect! Very nice results on the pit to date!
Offline GB
« Reply #16 on: January 21, 2018, 06:24:04 AM »
Thanks RAGIII
First attempt at HGW belts....
Decided that the PE coils were too flat and didn't really look that good, so replaced them with .010 lead wire wound round a drill bit and then coiled around a larger bit. Belts were then constructed as per instructions. Just need a little weathering before they are fitted.
« Reply #17 on: January 21, 2018, 07:19:40 AM »
Looking good, like what you have done thus far and looking forward to your progress.
Online RAGIII
« Reply #18 on: January 21, 2018, 09:35:54 AM »
The belts look great. I guess I need to give the ones I feared to start a try  ::)
Offline GB
« Reply #19 on: January 21, 2018, 11:37:35 AM »
Thanks Juan.
RAGIII. They aren't as difficult as you might expect. I complicated things a little with the coil, but it does make a huge improvement IMHO.
Belts weathered and fitted....
« Reply #20 on: January 21, 2018, 12:40:06 PM »
Gary,
    Wow! The belts and wood are superb! I'll be following your progress closely, I've built this kit and it's no "push over', you are really doing it justice and more. 8) 8) 8)
Offline GB
« Reply #21 on: January 21, 2018, 06:10:51 PM »
Thanks Lance  :)
Cockpit side frames now in place....
Online RAGIII
« Reply #22 on: January 21, 2018, 07:43:46 PM »
Your cockpit is looking terrific! I am looking forward to your next update.
« Reply #23 on: January 22, 2018, 12:16:48 AM »
Very nice progress. And I totally agree: the new coils make the belts looking even better. Great idea!
Borsos
« Reply #24 on: January 22, 2018, 12:24:39 AM »
Everything thus far is looking great, the seatbelts are little works of art.
Offline jeroen_R90S
« Reply #25 on: January 22, 2018, 02:13:24 AM »
Looking great -I'll shamelessy steal your idea for improving the seatbelts when I eventually get to a two-seater!
Offline GB
« Reply #26 on: January 22, 2018, 05:42:01 PM »
Thanks guys.
Controls next. HGW provide some PE aileron linkages, but the part is actually too long for the kit part????  However, it didn't go to waste. I removed the moulded on triangular brace on the rear of the styrene part, replacing it with the HGW part with the'cables' removed. The WNW PE part is then fitted to the front...
Once painted, along with the rudder bar, Ezi Line is added for the controls cables and painted steel colour....
Wheel yet to be added (need to add some cabling to the MG trigger on it), but other parts are fitted and cables carfeully threaded along their respective routes....
« Reply #27 on: January 22, 2018, 06:03:41 PM »
Great work, Gary. The colours look so right and the seatbelts are perfect.
Bye,Manni
Offline GB
« Reply #28 on: January 23, 2018, 04:58:51 PM »
Thanks Manni.
Column wheel is added along with MG firing cable....
Ammo box is then fitted along with instrument panel....
Onto the Bz.III engine next. I've removed most of the parts from the sprues, but it is going to need a fair bit of TLC to get a decent looking motor. Magnetos have some sink marks, upper crank case has a mismoulding which prevents one of the intake pipes from fitting correctly. One half of the cylinders has the rocker rods moulded into them - fortunately there is another half where they aren't,  though it's not referred to as an option in the instructions. Adding your own rods looks simple enough though. All part of the fun  ;D
Online RAGIII
« Reply #29 on: January 24, 2018, 01:41:22 AM »
Excellent progress! All is looking beautiful!
