Author Topic: Marek/Matt77 Aviatik Berg D.I in 1/33rd Scale  (Read 12134 times)
Online NinetythirdLiberator
« on: January 14, 2018, 04:25:30 PM »
As the Dolphin is drying, I couldn't resist making another paper card model. Here is the "kit"!
I then glued some of the former parts and structural members to some 1/32nd sheet balsa and started cutting some things out.  I did the fin/rudder and began the main bulkheads along with the start of the engine.  This one is particularly well rendered.  It's called a "re-paint" of the original Marek design by a modeller going by Matt77.
I just couldn't resist.  We'll see how well this one goes together.  Thanks for looking!
Dan
Re: Marek/Matt77 Aviatik Berg D.I in 1/33rd Scale
« Reply #1 on: January 15, 2018, 07:13:52 AM »
Great start on what is sure to be another remarkable build!
« Reply #2 on: January 15, 2018, 04:17:23 PM »
Thanks, Rick.  You need to try one of these guys...you'd do them justice.
Anyway, here is part of the building sequence for the basic engine.  I will be adding some more details to it soon, but here is the state of affairs...
I discovered that you can get cleaner paper folds and make the cylinders easier if you add a tad of water (hence the brush to apply it sparingly) to the paper and then form it.  I'll keep experimenting, though!
I'm going to add the manifolds out of paper soon...they look a little tough to do since their diameter is pretty small for me, anyway.
We'll see how it goes tomorrow.
Thanks for looking!
Dan
« Reply #3 on: January 15, 2018, 04:31:19 PM »
Wow, looks good, looking for the next steps.
« Reply #4 on: January 15, 2018, 09:59:51 PM »
Outstanding start Dan, really looking forward to your progress.
« Reply #5 on: January 15, 2018, 10:32:51 PM »
Great start of another of these fascinating paper models. Must follow.
« Reply #6 on: January 16, 2018, 03:51:28 PM »
Thanks, Everybody!  This has been a fun build...but I also realize that parts of the engine and interior are sort of fictitious or at least based on a different machine!  The engine, for example, has a completely different top manifold based on the shots I've seen and the magnetos are in the front!  Anyway, until I figure out some of that detail, I decided to work on the interior/fuselage.
The directions are pretty scarce and so most of this is pretty much based on my own intuition.  Here I also think that some of the interior pieces like the control wheel come from either a very early Berg D.1 or even (maybe) a picture of a Hansa Brandenburg Star-Strutter!  In any event, I wanted to use as much of the kit as possible so here is my attempt.
Some interior parts with the walls already folded and glued to the balsa bulkheads.  I thought the seat parts made sense, but in the end, I cobbled something together that looks ok but I don't think I'm using the parts correctly or as intended!
Here are the parts for the main controls.  Cutting them out was not easy task!
And here's what I got...I only added some paper seat belts.
Folded up...note the circular openings for light!  Cool.
Now with the engine bulkheads attached to make a basic forward fuselage...
And here it is sort of test installed.  With some more engine detail, it will look cool.  Can't wait to see if the rest fits!
Cheers and thanks for looking....Dan
Edit!! I just found some photos that DO show a control wheel!  They were apparently in earlier machines...live and learn!  I bet they had different engines too so I may be all wet!
« Last Edit: January 16, 2018, 04:22:06 PM by NinetythirdLiberator »
« Reply #7 on: January 18, 2018, 03:58:27 AM »
A bit more on this cool model!
I tried to figure out what kind of engine really worked in this guy...it seems it was an Austro-Daimler 150 HP engine.  Not well represented by the kit parts at all.  The more I looked at it, the more I realized I should've just scratched the entire engine!  But, I decided to just add a few things to busy it up and make it look better.  Still looks pretty nice in the end.
First, I made some valve springs...
I also added some spark plugs, wires that just terminate at the front of the engine (no mags as this would involve a new engine entirely since they are at the front of the engine) and I used some wire for the manifold.  The paper was hard to use and make it look nice.  I did, however, use the paper to make my exhausts!  I also cobbled together somethings resembling rocker arms.  Again, these are not correct for the intended engine, but increase the intricacy of the kit parts so I'm pretty happy.
Then I added the cockpit and edging along with the side/nose skins.  Starting to look pretty neat!
I'll begin working on the underside and turtle deck tonight.  Thanks for looking,
Dan
Offline Thumbs up
« Reply #8 on: January 18, 2018, 07:15:49 AM »
Wow! gotta get me one to.Nice one.
« Reply #9 on: January 18, 2018, 07:20:46 AM »
Looks great, the additional details add a lot.
« Reply #10 on: January 19, 2018, 09:18:52 AM »
Looking absolutely Fantastic! I love what you do with these kits!
« Reply #11 on: January 19, 2018, 10:48:37 AM »
It never ceases to amaze me what can be made from paper and in your very capable hands you make it look so easy, you have done a superb job so far, the engine and cockpit look excellent.
« Reply #12 on: January 19, 2018, 03:26:38 PM »
Thank you one and all.  Coming from this group, this truly means a lot.   :)
I added the top planking, the underside, the turtle deck and the fin/rudder along with the main wing spar. It needs a bit of touch up, but all appears well.  Coming along very nicely, I must say...
After I put the bottom on with its tabs, I realized they blocked the wing attachment...but it worked out just fine by simply bending the tabs up.  In fact, the extra friction made the fit better!  The spars are, by the way, 1/32nd sheet.
I forgot to mention that I also made sure to open up the control cable holes and glue some inside before closing everything.
More soon.  Although the Dolphin is calling!
Dan
« Reply #13 on: January 20, 2018, 04:02:14 PM »
Tail skid (which took some head-scratching!), stabs and wings.
All on, straight and without a hitch...I'll try the cowling tomorrow! Stay tuned.
Dan
« Reply #14 on: January 20, 2018, 05:45:37 PM »
You are moving ahead beautifully Dan, I'm very impressed with your work so far.
