Author Topic: Nieuport 17 "Flyboys", Eduard 1/48, Upd 27.2.2018 Weaponry Part II  (Read 33515 times)
Re: Nieuport 17 "Flyboys", Eduard 1/48, Upd 23.2.2018 Oil tank
« Reply #75 on: February 24, 2018, 09:08:33 PM »
The engine truly looks like you could fire it up! Outstanding job on the oil tank and filler pipes and caps .Finally the rigging is excellent!
Nieuport 17 "Flyboys", Eduard 1/48, Upd 26.2.2018 Rigging
« Reply #76 on: February 27, 2018, 06:14:10 AM »
« Last Edit: May 31, 2022, 01:36:30 AM by Bughunter »
Re: Nieuport 17 "Flyboys", Eduard 1/48, Upd 26.2.2018 Rigging
« Reply #77 on: February 27, 2018, 08:55:32 AM »
Absolutely beautiful Frank! The rigging is outstanding and the prop looks great. Whatever it is shape wise I am sure your next effort will be even better.
« Reply #78 on: February 27, 2018, 09:10:26 AM »
Looks great!!
« Reply #79 on: February 27, 2018, 04:45:52 PM »
WOW Frank, the prop is fantastic, and the rigging is perfect!
Offline KrzysiekK
« Reply #80 on: February 27, 2018, 05:29:21 PM »
Love this one!
17 looks like agile young lady ready to play :D
regards
K
« Reply #81 on: February 28, 2018, 01:48:34 AM »
« Last Edit: May 31, 2022, 01:36:37 AM by Bughunter »
Re: Nieuport 17 "Flyboys", Eduard 1/48, Upd 27.2.2018 Weaponry Part II
« Reply #82 on: February 28, 2018, 02:01:00 AM »
The filml does in no way justice to your model: Each and every one of your construction photos alone is much better than the whole movie...
Great little Lewis MG!
Online lcarroll
« Reply #83 on: February 28, 2018, 03:29:38 AM »
Very impressive Frank, the Lewis mount components are outstanding! Your new prop is superb as well, nicely done!
« Reply #84 on: February 28, 2018, 03:57:44 AM »
Thank you Andreas and Lance!
In meantime there is the show of the finished model, see you there:
https://forum.ww1aircraftmodels.com/index.php?topic=9343.0
« Reply #85 on: February 28, 2018, 09:01:35 AM »
Terrific results Frank. Like I said even better!
Offline Edo
« Reply #86 on: February 28, 2018, 03:59:24 PM »
the Lewis gun mount is eye popping!
while reading I was thinking that you made it workable....
absolutely astonishing!
ciao
edo
« Reply #87 on: February 28, 2018, 05:08:34 PM »
Wow, Frank, the plane is perfect and the Lewis mount is the cherry on top.
Bye,
Offline xan
« Reply #88 on: February 28, 2018, 05:12:48 PM »
oh i come too late ...
I saw tyour post yesterday but had no time to answer...
I my opinion you didn't have to take the Eduard prop as reference it is totaly not acurate..
first one was much better.
The prop you did was teh "Levasseur type 484" which equiped most of the ni-17.....
here are the real size (not very important for us...)
be carefull dran proportion are not accurate, only numbers are...
here you have a Levasseur type 586 (all Levasseur had same form)
so I think first prop you did was much better.
Second about wooden effect. your wooden prop are really amazing , but in french case props were covered with "gomme laque" first , then "Tonkylaque" since 1917/18
"Laque" means enamel in french...
it is between varnish and paint.
What I mean is that french props had very dark red brown apparence. and no wood effect was seen.
her some exemples, but i can show you more autochrome ...
here is what i did in a morane and in a ni-11...
if you are interest, to learn this effect i use a sand yellow base, the, i mix Prince august "woood grain" (70828) with tamiya red clear and pas several coats with pencil.
I am sorry all this come too late but anyway as you are represebting a replica, all is free prop have not to be accurate...
by the way could you please detalled step by step how did you do the prop? (kind od wood instrument to sant, haw do you cut and so...
they are the pretiest wooden rpops i never saw at 1/48.
Congratulations for the all work
Xan
« Reply #89 on: February 28, 2018, 11:40:38 PM »
Congratulations: this model is far better then the dummies used for the movie (and these were 1:1 scale!).
