Author Topic: Nieuport 17 "Flyboys", Eduard 1/48, Upd 27.2.2018 Weaponry Part II  (Read 33494 times)
Re: Nieuport 17 "Flyboys", Eduard 1/48, Upd 18.2.2018 Tail and windscreen
« Reply #60 on: February 20, 2018, 07:03:30 AM »
every part you are crafting adds so much to this build. The windscreen is awesome.
« Reply #61 on: February 20, 2018, 07:16:05 AM »
Thank you!
The inside cutout could be a touch bigger, but after the broken first try I don't want to overdo it. And at later state there was no chance to fix it due to the clear foil inside. But I can live with it.
Nieuport 17 "Flyboys", Eduard 1/48, Upd 21.2.2018 Weaponry Part I
« Reply #62 on: February 22, 2018, 06:32:47 AM »
« Last Edit: May 31, 2022, 01:36:10 AM by Bughunter »
Re: Nieuport 17 "Flyboys", Eduard 1/48, Upd 21.2.2018 Weaponry Part I
« Reply #63 on: February 22, 2018, 07:29:25 AM »
Wow Frank, continue to be amazed by your workmanship and details.  You give 1/32 a run for its money.   :D
« Reply #64 on: February 22, 2018, 10:12:14 AM »
Frank,
    Your "micro soldering" talents never cease to amaze me, amazing work! The Vickers is a real addition to the realism of this Build, just lovely work! (and the rest of the model is spectacular as well.) I'll be following your post as you finish up another really unique model.
« Last Edit: February 22, 2018, 01:11:52 PM by lcarroll »
« Reply #66 on: February 22, 2018, 02:56:05 PM »
Amazing work!!
« Reply #67 on: February 22, 2018, 05:55:48 PM »
Outstanding work! Frank you are a master!
Bye,Manni
« Reply #68 on: February 23, 2018, 09:32:29 AM »
Beautiful work on the MGs Frank! The PE Vickers is incredible!
« Reply #69 on: February 23, 2018, 05:10:18 PM »
Thank you very much for your encouraging comments from all you experts, that means a lot to me!
I have some reason to pull out all the stops with this built - with the gallery you will know the reason.
« Reply #70 on: February 23, 2018, 11:06:02 PM »
Your soldering skills are not from this world, Frank! I can't believe what I see here. The Vickers is incredible.
Offline markleecarter
« Reply #71 on: February 23, 2018, 11:41:06 PM »
Incredible!
« Reply #72 on: February 24, 2018, 03:54:40 AM »
Others have already used all of the available suoerlatives.... what you achieve with micro-soldering is quite exceptional. The rest of the build so far is also first class in every way: the metal cowling really looks the part. I am really looking forward to seeing this in the gallery.
Nieuport 17 "Flyboys", Eduard 1/48, Upd 23.2.2018 Oil tank
« Reply #73 on: February 24, 2018, 09:26:23 AM »
« Last Edit: May 31, 2022, 01:36:19 AM by Bughunter »
Re: Nieuport 17 "Flyboys", Eduard 1/48, Upd 23.2.2018 Oil tank
« Reply #74 on: February 24, 2018, 12:32:13 PM »
    Sheer magic Frank, what a beautiful model!
