Author Topic: WNW AEG G.IV (Late) 574/18 Canadian Aviation and Space Museum  (Read 77495 times)
Re: WNW AEG G.IV (Late) 574/18 Canadian Aviation and Space Museum
« Reply #180 on: April 04, 2018, 10:46:36 PM »
     Thanks for dropping in Rick and the "two Steves" and for your comments. Steve (Krow), the Taurus upgrades are right at the far edge of my abilities, much tinier then the blunt and arthritic fingers that are attempting to assemble them! Nice additions but hardly the peak of the modelling art with my inputs but I'll "get er done"! Presently I'm puzzling over the intricacies of the engine frame assemblies and cowlings as I want at least one power plant only partially cowled to expose the top end.
     Time to get into the two "How to Build" books a little deeper methinks! More to follow......... :o
« Reply #181 on: April 04, 2018, 10:57:51 PM »
...looking forward to it and we got snow this morning so a good reason to stay inside and model!!
« Reply #182 on: April 05, 2018, 12:02:54 AM »
      ..... one of the very few advantages of living north of the snow belt! ;) ;D
« Reply #183 on: April 05, 2018, 03:44:42 AM »
Just more good stuff, keep it coming !
Offline jknaus
« Reply #184 on: April 05, 2018, 05:27:06 AM »
Gorgeous Lance. Simply stunning.
James
« Reply #185 on: April 05, 2018, 07:03:08 AM »
The last weeks I had not really time for modeling, and more worse, not even time to follow such nice projects like this one!
Lance, the progress you made in the mean time is fantastic! Other said this already, but this will be a true master piece.
Please continue that way and have a lot of fun, it must be a great feeling in every single step to create such beauty 8)
« Reply #186 on: April 05, 2018, 07:17:53 AM »
Thanks Ed and James; and Frank, what a nice compliment coming from a modeller whose work I truly admire, Thanks a bunch, and I'm truly humbled.
I've just completed another side of the second engine with the Taurus top valves , springs etc. speaking of humbling! The progress is anything but fast at this stage but at least it's still moving forward!
« Reply #187 on: April 05, 2018, 07:56:05 AM »
Lance, I don't know how I could have missed all of your updates, but I'm catching up now.  Awesome modeling going on her, my friend!  Very impressive!
Same as Bud here. Great modelling results, Lance!
Offline kfutter
    • KLP Publishing
« Reply #188 on: April 09, 2018, 07:59:23 AM »
Just checking in for the first time in a while, and your progress since my last visit is fantastic, Lance! Bravo.
Kev
« Reply #189 on: April 09, 2018, 08:28:57 AM »
Thank you Prze!  ........ and thank you as well Kev, I've strayed off Karim's Build a bit here and there however I'm still very impressed with the amount of great info and tips in the book!
« Reply #190 on: April 13, 2018, 06:28:21 AM »
Just getting caught up with the AEG Lance:  Very nice work, truly master crafstmanship on display here.  The Filters have really set this apart as do the markings.  I haven't touched plastic in a month, but;..........your work is inspiring.  Looking forward to seeing the engines.
The new Hammond is taking a bunch of time, but the bench doth beckon.
Offline Trackpad
« Reply #191 on: April 13, 2018, 01:20:30 PM »
What they all said, Lance! Good luck with the engines as you progress with your build. I'm lucky: just had 1 x set of Taurus AM bits and bobs to sort out for the Mercedes!  8)
Cheers!
Offline krow113
« Reply #192 on: April 14, 2018, 01:43:20 AM »
Hopefully you can sort the engine and how to display it. A re-member here Michael Scarborough has done this with his AEG , exposing an engine , perhaps have a look at his work.
Look forward to an update...
« Reply #193 on: April 14, 2018, 09:58:58 AM »
Mark, Gary, and Steve,
    Thanks for looking and commenting. I've made zero progress since my last entry as I've just got back from a three day trip to deal with a family matter. All's more or less well and I'm looking forward to a little relaxation back at the model desk tomorrow. Just before leaving I went off on a tangent trying to add the plug wires to the plug wire "races" along the side.........  I didn't like the results at all so replaced it (Part E-6) with a scratched brass version. It still needs a bit more finishing and then I'll post a few photos.
« Reply #194 on: April 28, 2018, 08:14:53 AM »
    It's been two weeks and I finally have more or less completed the engines. The first of the tasks was to replace the ignition wire conduits with a soldered brass tube version. I'm the first to admit that I've got a long way to go to match Frank's soldering results however after a nicely braised finger here's the end product with most of the lumpy bits on the unseen side. Just pretend this is a scene for "Mr. Bean takes up Micro Soldering"!
    I wanted to try using mono line for the plug wires, it works but I won't do it again as it's a real test of manual dexterity and the results were not optimum. Before installing them I added the priming cups (Taurus) and left the valves for later
    Once the conduit and wires were completed I added the valves to the priming cups.
    Heres some shots of the end result on the port engine which will be left open with only the lower nacelle installed, all are "posed" on the mounts. The radiators were also installed.
    The Macro Photo shows I need a wee touch up on the decompression handle......
    The starboard engine details were kept to the top end only as it will be fully cowled and everything from the two manifolds down will not be visible.
      Next I'll start on the landing gear assemblies however I may take a break and go back to a little more work on the Clerget Camel for a change of pace!
« Last Edit: April 28, 2018, 08:20:51 AM by lcarroll »
