Author Topic: WNW AEG G.IV (Late) 574/18 Canadian Aviation and Space Museum  (Read 77493 times)
Offline Scrodes
Re: WNW AEG G.IV (Late) 574/18 Canadian Aviation and Space Museum
« Reply #120 on: February 25, 2018, 08:59:02 AM »
Thanks Matt! The HGW Belts were assembled with Medium CA, I prefer to do most glue joints with it and work around it's fairly fast setting tendencies. (I like the RB grain stencils however like weathering I find you can easily over do it, less is better in this case.
Thanks Lance. That's my go-to as well when not gluing kit plastic to kit plastic. I made the mistake of reading the RB belt instructions and following the direction to refrain from using CA. In retrospect some stiff belts would have been better for my mental health.
The directions recommended a glue stick... you know, because I have my grade three art supplies handy. I used Gator Glue applied with a toothpick.
« Reply #121 on: March 19, 2018, 03:28:19 AM »
    Here it is nearly a month since my last update! I started on the two engines and have managed to complete the top end of one with the Taurus Resin upgrades.
   Here is the completed top detail:
    The Machro features dust bits and dog hair were removed after this photo!
   The second engine has the resin rocker box assembly attached and at that point I elected to take a break and went back to working on the main frame components.
    The three upper decking components for the crew area were plywood with some aluminum panels and doors. They were painted in wood and Alclad II Dull Aluminum, then given a coat of AK Interactive "Worn Effects" in preparation for the final finish which will be weathered to expose some of the base material. The center section of the lower wing was masked and had it's aluminum walk strips added with Alclad as well. At the same time the major components were given several coats of Tamiya Gloss White as a base coat for the Aviattic decals.
    At this point the final color was sprayed onto the three upper panels and the molded plywood nose section of the fuselage. I elected to lighten the color recommended by the Instructions booklet for these parts. Tamiya XF-17 Sea Blue appeared stark black when tested so I mixed it with 50% XF-8 Flat Blue which resulted in the very dark but distinctly blue you see here. I'm much happier with that result and it matches my memory of the aircraft when I last saw it last September in Ottawa.
    At this point I completed the pre-shading process using Tamiya XF-78 Wooden Deck Tan, a little on the dark side however with the planned overspray of thinned black green as a filter to simulate the black green varnish applied as the final finish I'm hoping it gets toned down somewhat.
     I've now started the Night Lozenge decaling stage which I'll complete a further update on real soon. I'd like to complete that step before returning to the engine assemblies.
« Last Edit: March 19, 2018, 03:37:03 AM by lcarroll »
« Reply #122 on: March 19, 2018, 03:39:05 AM »
Looks beautiful Lance.  Lots of modeling fun, and am sure adult beverages consumed.  All kidding aside, great looking bird.
Offline krow113
« Reply #123 on: March 19, 2018, 06:29:17 AM »
Good stuff!
Thanks for showing the engine work , it looks a little daunting...
« Reply #124 on: March 19, 2018, 07:19:21 AM »
Excellent progress, everything is top quality.
« Reply #125 on: March 19, 2018, 07:38:36 AM »
The engines are looking outstanding  Lance. You have become the chipped and worn paint Master! Love where this one is going!
« Reply #126 on: March 19, 2018, 08:13:27 AM »
Thanks All for your comments, much appreciated!
Krow, the engine additions are indeed an eye test. I find it ironic how Lucacz can crank these beautiful little gems out with ease and I struggle to just put them together!
Rick, it's my first time using the AK Interactive worn effects products and I have to say I'm impressed! Less effort then the hairspray technique but they are a touch fast, less is better!
« Reply #127 on: March 19, 2018, 09:09:25 AM »
looking good Lance
Offline Scrodes
« Reply #128 on: March 19, 2018, 10:30:11 AM »
Beautiful work, as always. Those engines really look the part. I find it amusing that you and I both picked up AK's Chipping effects at the exact same time. Great stuff that works as advertised! I'm still surprised how much difference there is between the heavy chipping fluid and the scratches effect.
Keep up the inspiring work.
« Reply #129 on: March 19, 2018, 11:02:55 AM »
 Lance,
I absolutely love how well your chipping and scratching came out. The engine is equally impressive my old friend. Well Done!
Highest Regards ,
« Reply #130 on: March 19, 2018, 07:11:31 PM »
The chipping looks great.  Looking forward to more!
Gaz
« Reply #131 on: March 19, 2018, 10:05:40 PM »
Well worth waiting for this current update. You're doing great work, Lance! Congrats  ;)
vB
« Reply #132 on: March 20, 2018, 01:20:56 AM »
    Thanks for all the supportive remarks Gents. Scrodes, the AK Interactive products certainly do live up to their claims, great find and I'm a fan.
     I'm getting close to completing all of the upper surfaces decalling, hope to post another update shortly. So far, so good, but the touchy part of upper to lower joins is still looming ahead.
« Reply #133 on: March 20, 2018, 04:32:55 AM »
That chipping and scratching looks really good Lance. The engine assemblies look very good too - in line with the rest of this model which is fast turning into a large gem!
« Reply #134 on: March 20, 2018, 05:27:14 AM »
Thank you Stephen, it is the largest subject I've tackled in this scale and a bit intimidating at times! :o
