Author Topic: Dual Build: Roden 1/32nd Albatros DIII (OAW): Jasta 10, WNW ALbatrosDV: Jasta11  (Read 155873 times)
That's just beautiful, Rick.  Really subtle wood work too.  Makes the markings really pop!
Dan
Thanks Dan!
Wow Rick! This is very beautiful modelling! The subtle but convincing wood effects and neat markings make this come alive! I'm really enjoying this... Regards, Marc
Thanks for commenting Monty!
The wood really looks perfect, Rick, well done!
Ondra
Thanks Ondra. I appreciate your comment!
I have made a bit of progress on the Jasta 11 DV. I used Bobs Strippers to pre shade the wing tapes and then applied the lower surface Cookie Cutter Lozenge from Aviattic. These are the Best Fitting of the Cookie Cutters to date... They get Better and Better! I also did some interior work. A few touch ups and the controls still need to be done.
« Last Edit: April 14, 2018, 05:55:39 AM by RAGIII »
Offline ondra
Top notch work on the interior, Rick, well done!
Ondra
Ondra
Thanks Ondra!
Wow, Rick! This looks great. The interieur and the decalled wings look very nice.
Bye,
Offline krow113
Going well, the colorful parts will look very good when assembled.
Bye,
Thanks for the comment Manni!
Thanks for commenting. I may have been a bit conservative on my pre shading so might need to go back and do some post shading of the ribs. We shall see.
That interior is one to die for. The wings also look superb. Really Rick you set a standard which many of us struggle to achieve - and you seem to do ti with ease!
I love this Albatros. Especially the seat colors are very convincing as are the wings. It is really another great double that you are producing here, Rick. It is a joy to follow your progress.
Best regards
Thanks Stephen. The cockpit is pretty much OOB except for the seat which is after market.
Best regards
Thanks Andreas. I greatly appreciate your positive comment!
Good progress !  Interior is great. Shading nice and subtle.
Thanks Amigo!
I have had a pretty productive weekend. The interior on the DV is basically done. Just a bit of touch up here and there. I also finished applying the Lozenge to the wings ,upper surface, that is.
PS: I have used the Flugzeugwerke fuel tank. I added a paper backing to cover the hollow rear side that faced the cockpit.
PPS: I still have a bit to do to the left side  8)
« Last Edit: April 14, 2018, 05:56:24 AM by RAGIII »
Top notch modelling in every way Rick. Those cockpit interiors look fantastic - a standard to achieve!
Thanks Stephen. Your generous comments are appreciated!
