Author Topic: Fokker D.VIII Stripdown, Eduard 1/72  (Read 16729 times)
Offline ondra
Re: Fokker D.VIII Stripdown, Eduard 1/72
« Reply #30 on: July 31, 2017, 10:31:38 PM »
Well, I do have a soldering iron at my workbench (unfortunately in my other flat, so I can not check it right now) and I am afraid the tip is from a different material.
But this will not be a showstopper, copper tips should be commonly available from any DIY store.
Thanks for the advice!
Ondra
« Reply #31 on: July 31, 2017, 11:25:15 PM »
The prop is Outstanding IMHO! Beautiful work Frank!
RAIII
Offline RLWP
  • Bodger
« Reply #32 on: August 01, 2017, 03:47:12 AM »
Ondra
It is probably silver colour, making it a tinned copper tip
« Reply #33 on: August 01, 2017, 04:46:17 AM »
Can't see the pics Frank  :-\
Offline KrzysiekK
« Reply #34 on: August 01, 2017, 07:30:33 PM »
yes all thread - inspiring! But the prop in 72 makes the workers dream:)
regards
K
« Reply #35 on: August 02, 2017, 04:54:52 AM »
Thank you all for the comments! :)
If one day my boss/company don't like me anymore, may be I start then a serial production and sell such air screws. But this is so much effort, I have some doubt, that the work pays off.
One more question on soldering: is there any specific reason why copper tip is crucial?
There are some "life soldering tip", but copper has the best heat transport and there is a better connection between solder and tip. May be the other are working too, but I tried it and was not comfortable to a slightly different behavior. Hard to explain :-\
Guy, they are stored at Google, but I noticed sometimes a delayed loading. If the pictures are not there or only partly, try a reload of the page with the browser. Should work!
Fokker D.VIII Stripdown, Eduard 1/72, Update 3.8.2017 Engine and The End
« Reply #36 on: August 04, 2017, 06:22:12 AM »
« Last Edit: May 31, 2022, 01:37:59 AM by Bughunter »
« Reply #37 on: August 04, 2017, 08:33:16 AM »
No Frank, the thanks belongs to you.  Beautifully done Maestro.
« Reply #38 on: August 23, 2017, 07:39:16 AM »
Here is the link to the completed model:
http://forum.ww1aircraftmodels.com/index.php?topic=8758.0
Offline Gene K
Re: Fokker D.VIII Stripdown, Eduard 1/72, Update 30.7.2017 Wooden air screw
« Reply #39 on: August 09, 2019, 08:50:09 PM »
Air screw
The wood veneer is sanded down, partly to 0,3mm. I used the layers pear-boxwood-pear-pear-boxwood-pear.
Beautiful, as all the others have commented. Do you have a suggested source for thin veneer?
Gene K
« Reply #40 on: August 09, 2019, 11:43:08 PM »
Thank you Gene!
I know only veneer between 0.5 .. 0.6mm or thicker.
One example of shops (there are a lof of them):
 https://www.furniere-templin.de/
The problem is often, that those pieces are huge. In ebay you can find sometime smaller pieces.
I cut this standard thickness in stripes and sand it down.
For some wood I do not know veneer sources, so I cut my own on a Proxxon KS230, but that have to be sanded after that too, regardless of thickness.
« Reply #41 on: August 09, 2019, 11:55:44 PM »
Gene,
     Frank and I have chatted in the past regarding the sourcing of good quality veneers. He sources his supplies in Europe which is convenient given his location however I was looking for a source closer to home. Another member here provided this source in the USA and I am very pleased with their products;
https://www.syrenshipmodelcompany.com/
   I thin it down just a bit and it's great for the job. Excellent service and reasonably priced. I use their thinnest pear and Alaskan Cedar and am very pleased with the results. Check out their supply, I think you'll like it!
  Hope this is helpful and I expect Frank will provide other options as well.
« Reply #42 on: August 10, 2019, 12:02:34 AM »
Frank,
    My apologies, I sort of "stepped on your reply" to Gene but I think he's got a few options to pursue between us. Next time I'll read the newer reply first! :-[
« Reply #43 on: August 10, 2019, 12:15:12 AM »
Lance, no problem!
The shop you mentioned is great, because it offers more thick veneer (the thinnest is 0.63mm), so the WNW fans have a good source.
In Europe I have not found sources for Boxwood and Alaskan Cedar, both offered there :(
