Hints and Tips/Questions about modeling
GasPatch Models 1/48 Turnbuckles
Topic: GasPatch Models 1/48 Turnbuckles (Read 4074 times)
kuya
Newbie
June 12, 2017, 11:59:19 PM »
I'm planning to use these turnbuckles and never used them before is there any flex to them can the lower tab be slightly bent ? [img]
Pgtaylorart
Re: GasPatch Models 1/48 Turnbuckles
June 13, 2017, 01:00:00 AM »
There isn't much flex, but if you're careful and use needle nose pliers they can be bent a bit. Just don't bend them back and forth, they will break.
George
kuya
Newbie
June 13, 2017, 01:09:17 AM »
I love the scale look, but looks has its drawbacks ..thanks for the heads up
Pgtaylorart
June 13, 2017, 01:12:59 AM »
I use 1/48 Gaspatch turnbuckles on all my 1/32 Wingnuts kits. They look great and are better to scale than the 1/32 turnbuckles.
kuya
Newbie
June 13, 2017, 02:00:08 AM »
Really, I actually never owned the GasPatch buckles but I need to invest to see the difference, But I like your idea
I used Bob Buckles in the past very easy to use ,but mostly on 1/48
Des
June 13, 2017, 06:00:15 AM »
Quite a few of the forum members have said they use the 1:48 scale turnbuckles on their 1:32 scale builds, they say they look more in scale.
kuya
Newbie
Reply #6 on:
June 13, 2017, 06:44:20 AM »
Des
I'm definitely going to purchase is there one or two popular ?
skeeterbuck
Full Member
Reply #7 on:
July 08, 2017, 03:58:47 AM »
I don't use ant turnbuckles for 1/48 as no matter what is available they all look too large to me.
I just use a small drop of thicker enamel paint, white glue (which dries clear) or nothing at all except the eye bolt itself.
ALBATROS1234
Reply #8 on:
July 20, 2017, 03:18:38 AM »
I do mainly 1/48 and to me the gaspatch 1/48 buckles are a tad to big to look right imho they should change the package to say 1/32 on the 1/48 and 1/16 on the 1/32. I just make my own eyelets which are similar to Bob's buckles and use .5mm dia brass tube cut to 1 mm long for 1/48
kuya
Newbie
Reply #9 on:
July 20, 2017, 03:42:52 AM »
I did purchase a few GasPatch packages of the 1/48 turnbuckles and I do agree they are a tad large .
I have used Bob's tubing and eyelets and very satisfied with the results
Thanks for the input.
