Author Topic: A Long Promissed Project: HK Meteor Mk.4 1/32nd scale  (Read 63341 times)
Re: A Long Promissed Project: HK Meteor Mk.4 1/32nd scale
« Reply #105 on: December 13, 2019, 08:54:39 AM »
While waiting for the replacement markings for the right side I have begun to apply stencils and other markings. I ended up having to paint the walkway stripes. Applied black, masked with Bobs Strippers, then sprayed silver. Fairly happy with the results  8)
Offline Robin
« Reply #106 on: December 13, 2019, 09:26:55 AM »
Looks really good Rick!
Robin :)
« Reply #107 on: December 14, 2019, 12:06:20 AM »
Robin :)
Thanks Robin!
« Reply #108 on: December 18, 2019, 08:29:48 AM »
I received the replacement decals from Rowan/Pheon today at no cost to Me! Not just the ruined roundel and checks for the right fuselage but all of the markings portion of the set! Outstanding customer support as always! So now to put this one to bed  8)
Offline petero
« Reply #109 on: December 18, 2019, 08:50:15 AM »
That’s great customer support! You might want to test a piece that you don’t need, just to make sure there’s no recurrence of the shattering. Better safe than sorry!
Peter
Offline jknaus
« Reply #110 on: December 18, 2019, 09:29:13 AM »
I'm a bit late to the show here. Could you tell me what sized tubing you used for the exhaust? I have one of these partially done and have been thinking of getting back to it and finishing it. I need to figure out the exhausts though and your fix looks easy enough. Thanks in advance.
James
« Reply #111 on: December 19, 2019, 12:26:15 AM »
Peter
Great suggestion although I am pretty confident they will be fine  ???
James
My simple solution worked out well. If you look up the pipe without using a flashlight all you see is a dark tube. With a flashlight a dark tube ending in a blanked off manner  8) I measured the tube and oddly it is @ 14 mm Outside diameter and @ 12 mm inside diameter. IHTH,
Offline jknaus
« Reply #112 on: December 19, 2019, 02:26:14 AM »
Thanks. I'll look for some.
James
« Reply #113 on: December 19, 2019, 07:43:11 AM »
James
You are welcome. So a small update. The replacement decals worked as expected, no coating needed. The checks are now on both sides and most of the stencils applied. Again thanks to Rowan and Sabine for the OUTSTANDING Customer Support!
« Last Edit: December 19, 2019, 11:55:23 PM by RAGIII »
Offline petero
« Reply #114 on: December 19, 2019, 08:06:26 AM »
Looks great, Rick!
Peter
« Reply #115 on: December 19, 2019, 08:26:39 AM »
Looks great, Rick!
Peter
Thanks Peter, the end is now in sight!
« Reply #116 on: December 21, 2019, 04:55:37 AM »
Shaping to be another of your winning models Rick. The new markings really do look the business. As you write superb customer service from one of our specialised AM providers. My experience of these suppliers is very similar to yours - we are indeed blessed to have such good people.
« Reply #117 on: December 22, 2019, 12:50:35 AM »
Thanks for the Kind comment Stephen! We are indeed blessed to have such Good People to deal with in our community!
« Reply #118 on: December 22, 2019, 12:56:40 PM »
Excellent job on the decaling Rick , glad that everything work out great for you !
Offline Robin
« Reply #119 on: December 22, 2019, 08:07:07 PM »
Great stuff Rick!
With this "mojo seeker" done...what's next? :)
Robin
