Author Topic: Pfalz D.IIIa, Eduard 1:48  (Read 11891 times)
« on: May 26, 2017, 02:57:33 AM »
After your great interest I like to present my first finished model of 2017, a Pfalz D.IIIa
This comes as a Eduard Dual Combo kit in 1/48. Additionally another PE set from Eduard, HGW/Eduard fabric seatbelts, LMG 08/15 from Master and Gaspatch turnbuckles were used. Brass helped for scratching details and wood are used for the airscrew.
The paints are Alclad, Gunze and oils.
The sources of the original are questionable, but it looks so great that I could not resist to this colors.
Hope you will like it too ;)
Some detail views:
Re: Pfalz D.IIIa, Eduard 1:48
« Reply #1 on: May 26, 2017, 03:44:15 AM »
Who would not love a Pfalz D.III? And especially one so lovely colourful! It is a beauty in all aspects of modelling. Sincere congratulations!
« Reply #2 on: May 26, 2017, 04:48:37 AM »
Congratulations on a beautiful miniature.  I would think it a 1/32 if you had no stated that it was 1/48.  Outstanding   :D
« Reply #3 on: May 26, 2017, 05:07:14 AM »
   Beautiful clean finish and great detailing. I particularly like the results you've got with the wood prop, do you use veneers as I do or cut your own layer stock? Like your Nieuport this is an exceptionally well done model.
« Reply #4 on: May 26, 2017, 05:24:39 AM »
Thank you!
Lance, for some kinds of wood I have veneers (e.g. pear with 0.55mm), for others not. Here the dark is pear, the bright one is boxwood. I have to cut it to veneer at first (done with a circular saw Proxxon KS230). Often I have to sand the veneer down to around 0.4 ... 0.45mm, depending on the amount of layers and thickness of airscrew.
Offline kuya
« Reply #5 on: May 26, 2017, 06:16:57 AM »
You're not going to leave it without build details and it is a fantastic build
What did you use for paints what did you use for the Pfalz gray not an easy match
« Reply #6 on: May 26, 2017, 06:35:53 AM »
For red and green areas I started with Alclad white primer and then Gunze colors according to the Eduard manual.
The wings are primed with Alclad grey and then Alclad "semi matt alu", which seems to be a good match for the real alu powder color. Later I put small tapes ion the ribs and shadowed with Gunze smoke.
« Reply #7 on: May 26, 2017, 07:03:20 AM »
A gorgeous looking Pflaz Frank, you have done a superb job with this kit, the colours really are eye-catching and the prop is spectacular, well done.
Offline Dave Brewer
« Reply #8 on: May 26, 2017, 07:40:44 AM »
Indeed,another exceptional effort Frank.
Dave.
« Reply #9 on: May 26, 2017, 12:22:56 PM »
Very nice pals. Overall precise build .really like the prop
« Reply #10 on: May 26, 2017, 04:12:43 PM »
All the above!
Beautiful Pfalz  :)
Von B
Offline Cimmerian
« Reply #11 on: May 26, 2017, 04:41:04 PM »
Another beautiful model, most excellent work.
Regards, Ken
« Reply #12 on: May 26, 2017, 09:56:32 PM »
Thank you!
     That's not easy! Lovely work and exceptional results..........  well done!
« Reply #13 on: May 27, 2017, 12:55:03 AM »
Truly stunning, Frank.  One of the best looking and most finely detailed 1/48 Pfalz I've ever seen.
« Reply #14 on: May 27, 2017, 01:35:42 AM »
Thank you all for your nice feedback!
     That's not easy!
Lance, that's right! Otherwise everyone on this planet would make biplanes with wooden props ;D
Now I'm really wonder, what you will say about my (at least I think it is) masterpiece - this will follow this weekend 8)
