Author Topic: Nieuport 11, 1:48 Eduard  (Read 17647 times)
Re: Nieuport 11, 1:48 Eduard
« Reply #15 on: May 27, 2017, 05:18:56 AM »
Absolutely marvelous, Frank!  Did you make the tail skid assembly from laminated wood as well?
Offline kuya
« Reply #16 on: May 27, 2017, 06:21:15 AM »
Another fantastic build.
« Reply #17 on: May 27, 2017, 06:40:09 AM »
Bud, yes you are right, it is made form pear. The flat metal spring is a battery contact from a old cordless mouse, because other plates like brass are not able to carry the model. I have to use a diamond cutting wheel to bring the spring into that small form.
I started to scratch this after the model was painted, just the "wooden block" at the end was not. And I was not willing to wait a weak for the oil painting, so I started to work with wood again. Sometimes it is easier, if you have an idea earlier.
« Reply #18 on: May 29, 2017, 03:30:52 AM »
 Frank,
Absolutely amazing Nieuport my friend. Welcome to the BEST KNOWN WWI Modeling site in the known and the unknown Universe. It's always a real treat to welcome aboard such a talented new member. One question though,What took you so long to find us?
« Reply #19 on: May 29, 2017, 05:50:40 AM »
Gregory, thank you very much.
I don't see me as that "mastermodeller", more a "newbie with good progress in learning", because I still learn new things with every model. I try to keep and/or improve working methods, but find also new tasks with every new model.
I know the main page since some time, but have not realized, that there is also a forum. On the other hand I'm active in a german forum with build reports an so on, because it is much easier for me to describe those things in my own language.
« Reply #20 on: May 29, 2017, 06:21:44 AM »
  Frank,
My friend for a newbie you certainly did begin at the top of the learning curve. Well Done! Looking forward to seeing more of your outstanding works in the future.
Offline Syd Solo
« Reply #21 on: May 30, 2017, 11:56:51 AM »
Great modelling. I have been blown away by your output,and consistent quality.
Syd
« Reply #22 on: May 31, 2017, 03:29:04 AM »
Thanks, that is the output of the last two years with six models per year. I try to keep my quality and even try to do things better :)
« Reply #23 on: May 31, 2017, 02:15:20 PM »
I am running out of superlatives when commenting your third plane I have discovered here.
Borsos
I'm afraid I'm in the same situation - you make it very difficult to come up with the right words, Frank! Wow!
Offline kuya
« Reply #24 on: June 01, 2017, 09:15:57 AM »
Another fantastic build, thanks for sharing it with us.
« Reply #25 on: June 01, 2017, 09:32:12 AM »
Superb work Frank. Stunning! One of the best Nieuport models I have ever seen. Welcome to the Forum!
« Reply #26 on: June 02, 2017, 03:25:38 AM »
I'm in the same situation: with my limited english vocabulary it is difficult to say Thank you all! in a more intensive way for your fantastic feedback!
Offline poshboy
« Reply #27 on: June 02, 2017, 03:36:32 PM »
what a great model ;Dtell me how did you do the edging around the upper and lower wings,did you mask it yourself or did you use the eduard mask. I would like to do the same kit and was just wondering the best way to go about it. :D
« Reply #28 on: June 02, 2017, 04:41:52 PM »
Thx! The rips are masked with tape, but for the edging I have used the mask set. It is a bit tricky to get it on correctly, as one side is often wider than the opposite side :-\ After what seemed like 100 positioning tries it looks ok.
If you have small tape for the outline this will work too.  Or do the straight passes with normal tape and fill the corners with matching circles.
Offline poshboy
« Reply #29 on: June 03, 2017, 03:33:34 PM »
thank you frank that's what I thought about the eduard mask,but your idea of doing the straight edges then circles for the corners sounds better thank you I shall give that a try. ;D
